Need to identify
Hello All!
The other day, I backed my '86 Carrera out of the garage to get at some stuff stored in the corner. When I walked by where the car had been, I found a clamp laying on the ground. It had a decent amount of oil on it, so I was pretty sure it came from the car! :) When I looked for where it came from, I saw the following: http://forums.pelicanparts.com/uploa...1499550424.jpg It clearly came from the orange hose at the rear of the header/heat exchanger. It looks like I'm about to lose the one in the same position on the other side. http://forums.pelicanparts.com/uploa...1499550424.jpg I tried looking for the part in our host's lists, but I wasn't sure what to search for. Any ideas if they are available here or can I just find something at the local hardware store? Thanks, Rob |
Just a regular hose clamp. 70-90 mm I believe. Host has them. If you are picky and want them to match order all four. Measure your old one to verify size before ordering.
Awesome thanks! Just to be sure the dimension you list is the diameter, correct?
Yes. Hose clamps are specified by range of diameters they will work on...but...looking back at my paperwork....it's 60-80 mm range you want...check out Pelican Part HC60809-M130. Normally I wouldn't order a hose clamp but I couldn't find that size locally
Use the tear resistant type to save those hoses: NEW Genuine Volkswagen Hose Clamp (70-90mm) N0245184
| All times are GMT -8. The time now is 05:20 PM. |
