Fog Lamp Harness Question 82SC
I have a factory fog light harness and looking at the diagram it's easy to see the fuse box wiring but my question is the 2 brown wires with eyelet and the single brown wire with eyelet. I would expect them to be ground and it looks like one goes to the lug in front of the battery but I just wanted to make sure. I have spent 2 hours reading but have not found a answer.
Brown is ground.
Thank you, I guess my my question is what does the single one wire ground, ground to? The fog lamp main ( 2 wire with eyelet ) ground is connected to the ground lug in front of the battery. The part I can not find information on is the single 1 wire ground with a smaller eyelet that is going to the relay. I need to know what location to attach it.
Any chassis ground near the relay mounting location. Back of the fuse panel or it's mounting screws perhaps?
| All times are GMT -8. The time now is 06:52 PM. |
