rudycraigs's Avatar
Do 7" ATS cookie wheels fit on back of 1969?
I have a 1969 lwb unmodified 912 project. I recently got a set of 1979 ats 6"/7" cookie cutter wheels cheap without tires.
Will the 7" wide fit on the back of a 1969?
If so with what size tires?
I'd love some real experience before I risk buying tires etc. (yup every car is a little different but if the answer is likely no ithen I'll just find another pair of 6" for the back as well.
Thanks!
Old 07-11-2017, 02:45 PM
It depends on the rim offset (ET), tire width and camber setting. I believe you could make it work with 185/70-15 and 205/60-15 f/r. I would have dialed in more camber both in the front and rear, maybe as much as -2 degrees front and -2.5 degrees rear. Back in 1969 the car had 165/80-15 tires all around, and tire technology was light-years from modern tires. Modern tires require more camber, and more camber will significantly improve turn in, balance and stability in high speed turns!
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 07-11-2017, 03:26 PM
I had 6 & 7 cookies on my 72 with toyos ra1 205-50-15 & 225-50-15 with 2.5 camber in front & back.
I've added flares now.
72 911 coupe 2.7L S Cams/Webers Street/Track
68 912 coupe 1.6L sold
Old 07-11-2017, 04:10 PM
Shaun @ Tru6's Avatar
Yes, with 225s if you can find them. 7s all around
Tru6 Restoration & Design
Old 07-11-2017, 04:41 PM
Stock 77 suspension, 7" in the rears with 205/50-15 rubs in hard cornering with ~1 deg neg camber.
77 911s
16 981gts
Old 07-11-2017, 05:05 PM
What a great looking car....
Old 07-11-2017, 10:05 PM
Thank you, it's the best car I've ever owned. Has a 3.2 and is under 2200#.
Old 07-12-2017, 03:12 AM
Tags
cookie cutter , fitment , lwb , wheels and tires
