My observations with changing spark plugs
I've noticed some interesting issues when changing spark plugs...
It seems that you have to kind of 'guess' where the spark plug hole is. And if you aren't nearly 100% accurate at finding it, you risk shoving grime and dirt onto the spark contact points... or even bending the spark plug just enough that the gap measurement changes when hitting it against something. As for torqueing it... I don't have a torque wrench that would properly fit, so I just hand tighten it, then use the Porsche tool kit wrench to turn it a bit tighter until it catches. Basically, gauging the same amount of strength to take it off would be needed to put it on.... anyone have any other ideas as to guessing the amount of torque needed? I don't want to overtighten it... but also think it needs a bit more than just hand tightening it by turning the socket my hand. |
I tend to undertighten and occasionally have one come loose.
I'm not fond of ripping threads out of aluminum. |
There are lots of threads and tech. info. on tightening spark plugs. I've never torqued and never found one loose later. The washer is sort of a crush type so you really just go slightly past its crush point. Not really technical but its always worked, and I also use very light anti-seize.
If you use the factory tool in your tool-bag, you can guide the plug to the female hole pretty nicely without much bumping around and start it by hand every time. Tighten using the same tool which doesn't allow much leverage, don't brace up and gorilla the thing. You will not strip that many threads using the short handled factory tool. Shouldn't be much dirt or grime in the hole if you're plug wires are of the stock type where the top is shielded. |
But was reading that a lot of people (including some popular books) state to NOT use anti-seize. What gives?? why would this be a concern? I've always just used my finger to put a small dab onto all of the threads and wipe away the excess. Is there a major concern with anti-seize that I'm missing in our P cars??? |
18-22 ft lbs after Nm to ft lb conversion from the little SC spec book. Just a tiny bit of oomph. |
Torquing to spec with anti-seize may result with pulled threads. |
I think the NO ANTI-SEIZE thing is because people can be waaaay to generous using the stuff and then it gets everywhere it doesn't need to be. I understand that spark plug thread area is plated nicely so supposed to not need help. Like you state, I use only a tiny amount and try to be exceptionally careful. Wipe off all but a dab between a few threads. It is not a problem, just something we obsessive types like to do.
Hi boys..for spark plugs i have never use a torque wrench..there is no need to.As said above the crush ring is the sign it is tight.
also i use Wurth hhs 2000 for all lubrication places on 911...spark plugs ,omega spring, door stops and e.t.c. it is an excellent lubricant https://i.ebayimg.com/images/g/ehMAA...ori/s-l300.jpg |
Using an 85' as an example; spark plug gap: 0.7 - 0.8 mm (0.028 - 0.032 in). Spark plug to cylinder head: 30 Nm (22 ft-lb)
I noticed the last set of NGKs I bought had a different type of washer. Not sure I like it. I torqued them like always. Tighten until the washer stops compressing then a scotch more. Later when I pulled a couple they did not seem very tight. |
https://www.youtube.com/watch?v=CLR6pJR2AgY |
22 ft. lbs. feels like alot of torque to me, but I put my faith in the numbers. In the past when I torqued them by hand to a point that felt right, they were a bit loose when removing them. |
http://forums.pelicanparts.com/uploa...1499724431.jpg |
I'ld use some anti-seize instead of the HHS, Champion used to sell little bottles, I still have one. Just a dab to facilitate removal. They discontinued the recommendation because it contaminates the cats.
Well, y'all can ignore the warnings of using anti-seize, torquing to spec, and ripping your threads out of your heads.
Not my problem.... |
I is almost always hard to take mine off and I've seen plug flew out while driving, on non-porsche, and also so I always careful about this.
This tool, my buddy got it for me makes it a lot easier, and yes, I can torque my plugs to torque spec. https://c1552172.ssl.cf0.rackcdn.com/513474_x800.jpg Quote:
I love the factory tool! It works better than anything else I've tried over the years!
I use NGK plugs in my SC, and we've all probably seen the NGK tech bulletin that states to put them in dry. I put them in dry. I start by using a piece of rubber fuel hose about 8" long that I slip over the plug insulator. Then I hand thread the plug into the engine head using the fuel line. Get it hand tight down to the base and then apply the amount of rotation found on the NGK spark plug box with a ratchet. Something like 180-240 degrees off the top of my head. It's easy to determine a pair of 90 degree rotations with a ratchet.
For what it's worth, I also maintain a fleet of Subaru's with the 2.5 EJ engines. NGK plugs (spec) in aluminum heads on those as well. The Subaru Factory Manual specs 15 ft. lbs. torque on the plugs----dry-----and if using a "lubricant" to "reduce torque by 1/3 to prevent over-tightening." |
Trakrat. I had a plug come loose with a pop, pop, popping and damage the threads on #6 when it did. it cost me a top end with a time cert at 161K. Not sure how it came loose because I am very careful with tightening those plugs but it did. You can bet you azz I torque wrench each and every one of them buggers very carefully now. Factory tool with a torque wrench, that's the ticket.
I panicked when I didn't see it on there and had to put it back on a couple of them to work it back into the Porsche tool. |
As for 22lbs.... it DOES seem like a lot. I found a torque wrench that I had to buy (the only 2 I have start at 25lb setting).... tried it and turned it so tight that it still didn't 'click'... Not sure if I even trust my tq wrench I bought (a cheapie at an auto parts store). SO I backed it out... I wish there was some way to verify that my tq wrench is working correctly. |
They are very robust. You probably have them on the door striker receiver on the body side of the door sill. I think those are 8MM. O'Rielly's and Advance Auto have them. A set of four maybe for under $15. |
Trakart.... the 12 point is actually same as allen
That is most likely from 993 tool kit .. this one right? https://encrypted-tbn0.gstatic.com/i...WjYOVH_yocsfyw |
I had a plug pop out, to my considerable surprise on the front right cylinder of the 911 earlier this summer. I guess the PO didn't have them in there quite tight enough, and over the ensuing 10k miles that one just unscrewed itself. Fortunately the threads were find and I was in a location that made it easy for me to address the problem. Obviously I'm checking the other five.
http://forums.pelicanparts.com/uploa...1499809383.jpg |
yup it is from 964 kit..
Ivan |
I wish someone made a small size torque wrench for 5-50lbs/ft for tight areas.
Trying to turn my torque wrench on those spark plugs is tough due to the amount of movement it takes to click each tooth on the wrench to turn it. hardly any room with the fuel rails in the way. |
I do have a question though regarding spark plugs.....
Copper or Platinum? What's the pros/cons of each?? I installed the Bosch plugs that came with the maintenance kit on our host's site. I believe they are copper. I'm also installing Magnacore wires onto them.... but had a second thought that perhaps I should of gotten a better, higher performing spark plug set? |
| All times are GMT -8. The time now is 06:36 PM. |
