85eurocarrera's Avatar
Oil line to camshaft carrier?
Wth? Not even close. 3.2 Carrera.
Old 06-28-2017, 06:19 PM
You have to bend the left drop line to fit. The change has to do with the color of the metal ends as the gold hasn't been available for several years.
Bruce
Old 06-28-2017, 07:04 PM
Bruce
Really? No way I'm going to fuch up the little hard line. Maybe I get the old one rehosed at the hydraulic repair shop....
Old 07-12-2017, 04:31 PM
proporsche's Avatar
Hi ,don`t worry about bending the little oil supply line .This problem has been around since the 1980`s...Have look i just modified one on this engine and it works fine...use wise-grip pliers ..first bend it to the right and then left .
Ivan
Old 07-13-2017, 12:49 AM
Just a heads up. I know you were just test fitting but don't forget to put the washer between the oil line and the 17mm female bolt attached to the case when you connect it for real.
Old 07-13-2017, 02:10 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Had the same WTF reaction when I replaced mine.
My buddy bend it by hands by holding the tube between his thumbs and index and bending it outward while sliding his thums away from the bending point (multiple pass).
Who Will Live... Will See
Old 07-13-2017, 02:27 AM
Thanks for the pic and tips.
Mo -mon, thanks.
Old 07-13-2017, 03:52 AM
Dr J's Avatar
Same thing happened to me on my SC with oil-fed tensioner. I had to modify the small line on the driver's side. Interestingly, I recently did the passenger side and was expecting to have to fiddle with it, but the passenger side line fit right in with no mods.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 07-13-2017, 03:07 PM
