Need help stripping the coating on Targa top rain gutters
Does anyone know how to remove the factory coating on the Targa tap rain gutters? I have tried the following to remove the coating: scraping, sand blasting, grinding, paint stripper, Methyl Ethel Ketone, and methylene chloride. None of the chemicals work and the grinding and scrapping damages the aluminum. Sand blasting just bounces off the coating and eats the aluminum.
I really need help as my targa top rebuild is stuck in the mud. Thanks, Arron
1981 911sc Targa - gone but not forgotten. |
A sharp razor?
83 911SC Targa Everything I say is my personal opinion, and has nothing to do with my team. |
Yes.
I was able to remove a large amount of the coating with a razor. This was the coating that had already pulled away from the metal. I need a suggestion for the remaining coating it will not release from the metal.
![]() Can you use heat on the remaining coating?
Are these parts powder coated?
I have an interest because I started to remove the rain gutters from my car yesterday for re-painting but It's to cold here to paint so I decided to wait for another time. I figured to sand prime and paint but maybe not.
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
In the end I was able to scrape off the coating on the visible areas of the rain gutter. I decided not to try and strip the other as its coating is not damaged. For now I painted the stripped rail with metal etching primer and lacquer paint. arron
pictures
Factory coated rain rail on top
Stripped rain rail on bottom
have you tried aircraft stripper yet? it may take it off, and it may just soften it enough to make it easier to deal with.
Bumping this old thread. I need to strip one of mine and repaint it. What have you guys used? And, is removal easy?
