Parts ID
Need help can someone tell me what the parts are on this shaft , I need to order new ones. Looks like some bushings too.
thanks
Old 07-18-2017, 12:17 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - if our members are not able to help with identifying the parts, please feel free to contact us via the link below (select Technical Question) and attach the photos; a Porsche part specialist may be able to help out with IDing them. Lastly, if you need any assistance with parts, give us a call directly at 888-280-7799 and we'll be happy to help out.
Contact Us
Old 07-18-2017, 12:27 PM
proporsche's Avatar
Hi... here are the bushings you need 2x
914-423-211-00-M260
and the bell crossover linkage level..
91142301701
i am surprised that Dimitry does not provide you with this basics??
Ivan
Old 07-18-2017, 12:43 PM
That is the linkage to your throttle. The part the looks like a paperclip goes up to the engine where it has another link going to carbs or injection pump. It is called the accelerator pull rod, 90142302603.
Start from there and you can probably get PNs and names for the remainder
1969 911E SOLD
2002 996 Cabrio
1995 993 Carrera 4 SOLD
parts
Thanks guys. I looked for over an hour at the parts catalog and could not find it.
Wow what great help from all of you!!!!
Old 07-18-2017, 01:01 PM
steely's Avatar
Spring for the bronze bushings if you can : 914-423-211-00-M105
The bell crank itself looks aok apart from a little cleaning/lube TLC
There's another similar to it on the eng deck under the intakes.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 07-18-2017, 01:09 PM
proporsche's Avatar
+1 Dan..... yup copper is better for bushings
Ivan
Old 07-18-2017, 01:17 PM
I knew it only because I've dropped it on the ground more than once!!!
1969 911E SOLD
2002 996 Cabrio
Old 07-18-2017, 01:23 PM
proporsche's Avatar
WJL911..here have a look at this a save it
ivan
http://www.porsche.com/all/media/pdf/originalparts/usa/911-1_USA_KATALOG.pdf
Old 07-18-2017, 02:19 PM
+1 on using the parts catalog.
That's how I identified all parts when I restored my 911 back in 2011
Armed with the right part number, you always end up with the right part.
Worth its weight in gold.
Parts catalogs for pretty much all years are available, or you can buy them on a CD on ebay.
83 911 SC, 3.2L bore, 964 cams, 46mm PMO carbs.
Old 07-18-2017, 03:04 PM
Thanks Ivan. Saved
Old 07-18-2017, 04:01 PM
As bad as those bushings look, the bushings in the pedal cluster will be just as
bad. You won't feel any slop as the assy. is under spring tension. At the motor
end of that rod you will find another bell crank. Those bushings will be bad also!
I'd use the bronze ones over the copper ones.
Old 07-18-2017, 05:07 PM
Everything looks dry, in need of lubricant...
Bruce
Old 07-18-2017, 06:59 PM
dry for sure. Just got done power washing the major stuff off. need to hit it 1 more time to get it clean then lube everything. still having a shifting problem in 1 an 2 an want to start tracking that down. But ran into this first which needs repair badly.
Old 07-19-2017, 05:00 AM
steely's Avatar
can I ask what the model year is? (the pdf link comes up as '69 for me anyway)
Ivan is correct that the PET catalog is a major help - I've used mine a lot, but this link may be more appropriate (no disrespect intended).
Porsche Classic Genuine Parts Catalog - Porsche USA
Dan
Venetian Blue
Old 07-19-2017, 11:01 AM
proporsche's Avatar
sorry wjl911 my mistake..try this
choose a model here
Old 07-19-2017, 11:28 AM
