Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Clutch cable brand
I'm rebuilding my pedal cluster and figure I might as well replace my clutch cable while I'm in there. Our host lists 3 cables for my 82 sc at $23, $56 and $183 for oem. Any reason to not use the cheap one?
Old 07-16-2017, 12:09 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Hi
Targa Me's Avatar
It's been my experience that the less expensive cables then to stretch, the cable diameter is thinner and seem to wear out quicker.
My Pcar is a daily driver so I buy the OEM.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 07-16-2017, 04:39 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Curious to hear other feedback here as well. Is the Porsche one at 3x the price 3x better (or even somewhat better) or is that just what they decided to charge for it these days because they can?
1986 930, 1969 Mach1, 2003 540 Sport, 2016 R1200RS
Old 07-16-2017, 06:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
sc_rufctr's Avatar
The OEM one is not 3x better but it will work properly for a lot longer than the cheaper options.
Ultimately it's your choice but this is one of the parts I'd only buy OEM.
One thing of note. Make sure you check this bracket & the studs holding it onto the transmission.
On my car it was bent and the studs were also pulled off center making it difficult to get the side cover off.
I thought I had a stretchered clutch cable but this affected the travel of the clutch release arm.
Once the studs and bracket were replaced the clutch worked as good as new with the original cable. You can also get an after-market steel version of this bracket.
Peter
Old 07-16-2017, 07:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
gtc gtc is offline
abides.
gtc's Avatar
I have a Cofle cable ($23) waiting to be installed. Looks fine to me.
Graham
1984 Carrera Targa
Old 07-17-2017, 09:46 AM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
theiceman's Avatar
I sprung for the middle of the road cable and got the gemo one. It was over twice the thickness of the previous one on there and looked very robust. the Only disappointing thing about it was it was not yellow zinc cad if you care about that stuff. Ive had it on for a couple of weeks now with no issues.
I also ordered a replacement clevis fork and clevis pin as its pennies really and a busted clevis pin will ruin your day .
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Nissan Murano (Audi Support Vehicle)
Old 07-17-2017, 03:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
