SalParadise's Avatar
Options on '75S Front Brake Calipers
What are my options for the replacement of '75S front brake calipers? I want to get the car on the road ASAP and don't have the time to rebuild the alloy S calipers currently on the car, so I was wondering what I could put on there for now that are more readily available and maybe I could find that are good/used and ready to bolt on.
Old 07-16-2017, 08:48 PM
seafeye's Avatar
Early 911S Aluminum Calipers
FS: Alloy S Calipers 72/73S, RS Carrera Turbo
Or these may work as well...
FS SC front calipers
What me speed?
Old 07-16-2017, 08:54 PM
djpateman's Avatar
The standard "A" calipers will be a bolt on replacement; they just use thinner pads.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 07-17-2017, 06:00 AM
So I can place any SC or Carrera front calipers on it with my current stock setup? I don't care about replacing the pads (obviously) but if I can find a good clean working pair of anything at this point while I rebuild the originals it would help.
Old 07-17-2017, 06:05 AM
gearhead
PMB might have a restored set of S calipers on the shelf you can buy on a core exchange basis.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 07-17-2017, 07:10 AM
Once a friend of Cliff
juanbenae's Avatar
not to highjack, but I have been looking for a guide to rebuilding the S calipers. does anyone know of a thread?
so, on topic. I would suggest that the Carrera calipers would likely require changing out the rotors too as they are 24mm where as the SC, and likely S units take the 20mm rotors.
Old 07-17-2017, 07:30 AM
djpateman's Avatar
I would not say any. There are the "A" calipers for the 20mm rotor you have and the "wide A" for the 24mm rotors on the later cars. Stick with the standard "A" caliper.
These caliper really benefit from a full restoration by PMB. The need to be deanodized, cleaned up, and reanodized. Then they will be protected against corrosion again. The piston almost always need to be replaced. I no longer bother rebuilding these calipers, and just send them to PMB. Just like Fuchs rims, these Fuchs/ATE caliper need the hands of experts with the correct processes.
Addicted since 1975
Old 07-17-2017, 10:27 AM
