-   -   MSD coil with Permatune box 911SC? (http://forums.pelicanparts.com/porsche-911-technical-forum/963550-msd-coil-permatune-box-911sc.html)
zje 07-17-2017 07:25 PM
I am troubleshooting what feels like an intermittent misfire on an 83 SC. The car has an MSD ignition system and an MSD high vibration coil currently installed. I have a spare blue coil and permatune CD in a box as well.
I will check resistances based on this page: https://www.msdperformance.com/products/coils/performance_street/parts/8222
But I am also wondering if is it safe to test the permatune box with the MSD coil at some point?
A previous search revealed the thread linked below, but that was for a 912 and I'm not sure if that same advice (don't do it) applies to this car/setup:
http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/2774-msd-coil-permatune.html
Thanks!
schoward 07-17-2017 08:23 PM
I am sure others will chime in but I thought you could run the msd high vibration 8222 coil with a permatune. Threads with John walker and warren hall on this.
zje 07-17-2017 08:41 PM
Got it, found this thread: http://forums.pelicanparts.com/porsche-911-technical-forum/951142-compatible-coil-needed-permatune-blue-box-3-pin.html#post9529199
Not sure if the difference between the 6-pin boxes and 3-pin boxes would matter here.
Thanks!
