Gonna have to go to church twice on Sunday!!!
Been cusssing so much this last hour, wish I knew some german swear words.
Ordered new fuel injectors and sleeves. The injectors aren't too bad BUT them Sleeves. I have the notches...... any easy way besides trying to file the notches ![]() W. |
Registered Minimalist
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Ah HA .... I have a dremel!!!!
Put an injector in the bottom of the insulator and drive it out. The build kit has the rubber "O" ring in it for the outside of the insulator.
Bruce |
Flat6 the engine is still in the car. stuffed some paper towel in the hole, got the dremel out and it went a lot better.
All 6 are out! |
Scheisse is the word you are looking for. It is the swear word for poop. (pronounced: Chi sa)
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold )
Use a Dremel, drive them out from underneath with a punch, really clean it up inside and put the new o-rings/sleeves in, and then use another punch around the outside(top) to crimp them in. I did not use a flat punch/chisel when putting them back in, but a round one in 4-5 places around the top edge.
I used a short, sharp pocket knife to cut out the stakes in the aluminum. Then I used an easy out to pull the sleeves. That wasn't to bad.
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
