LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Plug look like I'm Running lean?
New ngk bp6 1,000miles ago
What do you think, lean?
Old 07-19-2017, 09:13 PM
Under the radar
Trackrash's Avatar
Lean is a relative term. If that came out of my car, I would put larger jets in my carbs.
Most FI systems with smog controls will be relatively lean. What car did that come out of?
I guess you could run your car on the dyno and make adjustments depending on your results.
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-19-2017, 09:52 PM
3.2 carrera
Old 07-19-2017, 10:04 PM
T77911S's Avatar
how many miles on the plug
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-20-2017, 04:22 AM
Chain fence eating turbo
Looks perfect. Yours is clearly running correctly at stoch.
The true test would be to run it to redline in all the gears, and immediately shut down, and then read plugs.
That will tell if lean.
Looks like idle and part throttle AFR's are exactly where they should be.
Old 07-20-2017, 06:13 AM
With todays unleaded fuels, you can't tell much from plugs anymore.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-20-2017, 06:32 AM
Ok thanks guys thoes plugs have 1k miles on them ,
I'm having some high rpm running issues. Loss of power above 4.5 k rpm. Car feels like it's not getting gas ? Maybe "feels" lean?
I've recently replaced the following.
Valve adjustment
Cht
2 reference sensors
O2 sensor
Plugs
Wires
Cap&rotor
Fuel filter
Pre muffler & sport muffler
Checked my tracks on afm
Fuel pressure is 30psi at idle 37 with fpr disconnect.
Checked for vac leak none , I'm getting a nice drop in rpm when I open the oil cap.
Any suggestions ?
Thank you
Old 07-20-2017, 07:25 AM
Check continuity of "WOT switch".
Sounds like your WOT map in the DME is not getting triggered. This will cause your symptoms.
It's where a traditional TPS is located on the throttlebody in black.
Old 07-20-2017, 07:39 AM
Yes checked wot switch with multimeter it's good and is engaging at 3/4 throttle .
Old 07-20-2017, 08:30 AM
A bone-white insulator without any coloration suggests a very lean mixture, however one needs to know whether the ignition was cut at higher RPM or simply removed after idling for a few minutes. There is a very specific procedure for performing a plug cut to accurately read spark plugs.
I'd strongly recommend a chassis dyno session to confirm AFR's and whether its making proper HP to the wheels or not.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 07-20-2017, 09:36 AM
Thanks Steve ,
I just cruised home from work at 60 mph no high rpm and parked it.
I have no access to a dyno. do I have any other options?
Old 07-20-2017, 09:53 AM
Originally Posted by 911 sc View Post
Thanks Steve ,
seems you're looking to see what a wideband oxygensensor would show your mixture to be across rev ranges -- in other words whether it's leaning way out as your rpms increase. Easy to do on a dyno, but also can be done by replacing the standard oxygensensor with a wide band one and adding a logger yourself.
Old 07-20-2017, 10:01 AM
Under the radar
Trackrash's Avatar
An air fuel gauge is an easy install.
https://www.google.com/search?q=aem+air+fuel+gauge&ie=utf-8&oe=utf-8
Gordon
Old 07-20-2017, 10:33 AM
Under the radar
Trackrash's Avatar
Gordon
Old 07-20-2017, 10:34 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
What do the other 5 plugs look like? That one almost looks like it was in a hole that wasn't running. certainly doesn't look like 1k miles
Old 07-20-2017, 11:49 AM
I know that's what I was thinking , so I pulled all six and they are the same !
Old 07-20-2017, 11:56 AM
smokintr6's Avatar
weird... I'd check with the wide band next. It sure seems like you've covered most of the bases
Old 07-20-2017, 12:01 PM
T77911S's Avatar
have you checked the pins at the DME connector for the throttle switch.
put the meter on those pins the go WOT.
a BP6 plug and you most likely shut it down at idle, I don't think this is an indication of your problem. if it is then you are lean at idle too. try a BP7, not that that will fix your issue.
(I don't know what most run in this car).
really sounds like the DME is not going richer when it should. throttle switch problem as in the DME is being told to go richer or DME.
maybe FP not delivering the required volume of fuel.
RACE CAR:: sold
Old 07-21-2017, 03:57 AM
RETIRED
Joe Bob's Avatar
Put it on tail pipe sniffer, answer all your q's.....
2012 ML350 3.0 Turbo Diesel
Old 07-21-2017, 08:15 AM
It's odd running lean with 02 plugged in and rich unplugged ??
Old 07-21-2017, 09:15 AM
