2.2S Aluminum P.P. FOR 915 Gearbox?
Hi,fellow Pelican member Dick Shift from Hawaii said you can use a light weight 2.2 Pressure Plate on a 915 gearbox.I sent him an email & PM over the last 2 days but no response.Does this fly?I am in C.R. so I can not look at two and compare them.One is push and the other is pull.Ciao Fred
Old 01-10-2018, 04:59 PM
Under the radar
Trackrash's Avatar
The pressure plates from '70 on will work with a 915. The clutch disk and TO bearings are different between the 2,2 pull clutch and the 915. The pressure plates are all pull clutches, the 915 just uses a different release fork and has a bigger input shaft spline.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-10-2018, 06:33 PM
Fred, U gotta change Ur locations! Expecting to relocate to SouthPort,NC in a year, maybe 1+. Happy New Year !
Sent from my VS501 using Tapatalk
Old 01-10-2018, 06:43 PM
Check out KEP clutches. They make light weight aluminum pressure plates. I just installed one on my car.
Old 01-10-2018, 10:30 PM
I would rather be driving
jpnovak's Avatar
Yes, 2.2 225mm Pressure plate and Flywheel will work with a 915 as long as the clutch disc and TOB are swapped for the appropriate 915 units. The clutch disc splines are larger for a 915 to match the larger input shaft.
Old 01-11-2018, 06:34 AM
It's a 914 ...
stownsen914's Avatar
In line with the others' comments, I agree that they are interchangeable. I did the reverse in my case - I have an aluminum pressure plate from a 915 car on my 901/911 trans using the 70-71 style 225mm clutch. I have a 2.2S 225mm pressure plate like the one Dick is selling and tried it, but switched to the 915 unit cuz I was getting clutch slippage with my race motor. The 915 version has a little more clamping power.
Scott
Old 01-11-2018, 11:00 AM
