Cutting Euro Fender Turn Signal Hole
Hi, I'm looking for a new fender for my '85 euro and wonder if the only difference between the euro and non-euro fenders are the hole for the turn signal? It's been much easier to find affordable (re: used) non-euro fenders over here in north america and I'm considering the DIY route if it's possible. Is that hole something that can be carefully cut into a non-euro fender? The car is a couple of hours away so I can't go out and take a look, thought I'd ask here... not sure if the sheet metal is stamped or has a negative relief for strength or if it's literally just a hole. Thanks!
rollandburn1985 911 Carrera |
cycling has-been
Leave it off - no one will ever notice. - unless it's required in Canada.
Think of the weight savings! ![]() Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
I have a driver side Euro fender I might decide to part with.
2001 986 S |
I have thought about doing this to my US spec '87 because of the safety factor (better visibility for drivers next to you), and did some research here. See this thread from DRACO. Looks like just two holes. The only thing not clear to me is where/how the wire harness is routed; I don't see any plugged holes on my car. This makes me think the Euro fenders have more than the holes for the light; they may also have holes to route wires. If anyone out there with Euro fenders cares to chime in, it would be interesting...good luck.
European Side Marker Light Location
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
![]() Mark |
The previous owner of my car drilled holes to install Euro side lights. My car is a ROW car, but it's a 79, it didn't have them originally. So the wiring used to add the lights is really hokey. I'm actually weighing options to remove them without having to repaint my fenders.
hmmm ok, thanks for the feedback. I'll take a closer look at the fender this weekend to see what sort of cut out the original has... cheers.
I did it myself about a month ago. I measured and measured and.... then marked out the holes. The big one was too big for any drill bit I had so I drilled a series of small holes to make the circle then used an abrasive stone in the drill to tidy up the hole and to remove any sharp edges. The small hole was just a 8 or 10mm so that was easy. So in other words, no big deal just half an hours work.
Yup... same fender.
I bought a used (euro) right fender for my 79SC ROW. My car doesn't have the side markers. Not sure what year the fender I bought was but I had to weld the marker holes and also the antenna hole (my ant. is on the drivers side).
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
In my best foreign accent "NOW you tell me."
Yep... That would have worked fine. At least the gunshot blast looking hole I did will be covered by the side indicator which is quite a bit bigger than the hole. |
Eh, I don't think they're a well known tool. I learned about them because I worked an electricians shop, they use them for custom electrical box knockout, making wire routes through steel wall studs, etc. Super cool for some very specific things, but not a replacement for your normal set of drill bits.
Is it possible to run wires to turn signal in front fender and connect them there?
This is all great to hear. Spent a small fortune on a step drill bit to get through the wheel well (sway bar install) and will be happy to put it to use again.
thanks again! Sent from my iPad using Tapatalk
