-   -   Replacing MK muffler with stock (http://forums.pelicanparts.com/porsche-911-technical-forum/964048-replacing-mk-muffler-stock.html)
roper0621 07-22-2017 07:11 AM
I'm trying to go back to the stock muffler, I believe the existing one is a MK. Had a local exhaust shop try to install the muffler it would not line up with the by pass pipe. Is there a difference in by pass pipes?
Geronimo '74 07-22-2017 07:15 AM
I don't believe there is.
M&K mufflers are set up to bolt right on the OEM cat or bypass.
RarlyL8 07-22-2017 08:07 AM
Depends on the bypass pipe. We (M&K) use the stock catalytic converter for our fixture points for both our MKM32 premuffler and MKM60 bypass pipe. We also use the OEM banana muffler for our fixture points on our single inlet mufflers. That being said we run into this problem all the time, which is why we made the single inlet mufflers adjustable. These are 30+ year old cars, the OEM systems warp and spring out when unbolted and if the OEM heat exchangers have ever been removed they were likely bolted back up in a different position due to that warpage. There is a LOT of adjustability in the 9 bolts holding on the catalytic converter and the 12 bolts securing the heat exchangers. If you loosen the 9 bolts on your bypass pipe there should be enough adjustability to install the OEM muffler.
roper0621 07-22-2017 03:02 PM
Can I expect a quitter sounds with the stock muffler?
