JWest shifter length.
Thinking about buying Jwest shifter
They come with 2 shifter lever options. Do you guys know the actual length of them? Short and Long? I would like to mock them in my car and see which one I order. Thanks
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
I have the longer one in my car, I can measure tonight when I get home from work. I will measure from the base of the shifter housing (where it meets the tunnel) to the top of my shift knob, while in the neutral plane. FWIW, the extended shift level is an excellent option, puts the shifter more in line with where it should be IMO.
Edit: or give me the dimensions that your are specifically looking for and I can measure that as well.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
I agree I have the longer Shift lever and a longer knob on my JWest Rennshift and I also put a 1" spacer behind my Momo Wheel, perfect fit and feel for my and I am 6'1"
Ächtung Kraft Founder - Custom Porsche Parts and Leather http://achtungkraft.com - Bryan Rasch - bryan@achtungkraft.com INSTAGRAM // @AchtungKraft // @BrightonRennsport 1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain 1976 911S + 2006 911 4S + 2009 Cayenne GTS + 1988 944 |
Bought both, went with short.
72 911 Although it is done at the moment, it will never be finished. |
This is on my friends car.
Im 6.1 and I need a little more lenght This JWest shifter is 12.5 inches to the top of the ball in neutral. Is this one the short or taller lever version?
This is my long version, I'll try and meassure it tomorrow
Help with measurements??
JW Shifter
Hello
I Wanted an extra long shifter and I ended up mixing brands. I installed the JW long shifter and the WEVO long knob. The end result is a very long shifter that it is closer to the steering wheel like on rally cars and makes the hand transition very effective and comfortable.
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you." |
GOM (Grumpy Old Man)
I have the long Rennshift lever and it is approx 9" end to end using a straight ruler. It is the perfect length for me and doesn't require any reach when shifting. I hope that helps.
Instagram: @3pedalposse |
Dial 911
Hi...Will the factory leather boot cover the complete JWest shifter -aka- Renshifter, or is that not possible due to it's mechanism? (1986 Carrera)
Thanks in advance!
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 09-29-2017 at 03:27 PM.. |
JW Shifter
Cheers
