Messed up my driveshaft repair
Hi.
I was suspecting a weird noise coming out of my rear right side to be the driveshaft. I decided to chech its condition by dissambling it. While taking it apart i broke the outside thin metal cone where the boots larger side attaches. I thought that this was a part easy to replace.... I mean the golden part on the right side of the axle. Is there some selling this part? Any Ideas? I dont want to replace the whole axle...
911-87 mit der 3.6 V-Ram und alles spaß |
Are you referring to the cone shaped part on the very left of the shaft in the photo? The part that goes into the transmission flange?
If it is truly the part on the right side, that is attached to the boot. The boot and that part are purchased as one assembly.
Sorry for all these responses...my sc is different. The hub spindle and cv joint are separate parts. That assembly appears to be all one unit.
The SC shaft is a bit different. I mean the part on the right side of the picture
3.4 Bigger is better
Here is a link to what I did to see how the cover came off
Update Carrera CV Boot replacement
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
