LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Discseven's Avatar
Coast... Car I'd never finish. Air bucket will be done this year.
Karl ~
Current: '80 Silver Targa w /'85 3.2
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver 930. '79 Black 930. '79 Anthracite 930.
Old 02-02-2018, 12:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #221 (permalink)
Discseven's Avatar
Starting reference... 11 1/16".
Adjustments... Channel for engine release cable has been pulled down slightly by crevice area. Duct area that fits into crevice has been wedged-formed more. Duct area just ahead of crevice has been squashed. Above is inside view of duct is looking away from intake end. 3" OD duct would now seem a better solution in terms of fitment above wheel. How air flow would react to narrower passageway is questionable. (Am staying with 4" OD.)
13/16” raise accomplished. (Realize now I did not place tape measure in same position for second reference. Tape measure is in a more vertical position second time. Might make a 1/16" difference. So 3/4" riase.) Can raise more but need to lengthen duct so it can arch up further. Have extended as much as possible now by resetting existing couplings. Got maybe 1" more duct length. Would need to replace a coupling with longer version to get length needed. Will run this position and see what happens.
Karl ~
Old 02-02-2018, 01:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #222 (permalink)
Discseven's Avatar
1000 mile marker
Am looking at parts to check install is staying installed and for damage. Turbine blades are not checked at this stage due to the challenge that exists to remove and reinstall unit---problem being the insulation. Taking turbine out is easy. Putting it back in watertight condition is less so. For now am relying on sound to say turbine is working (sounding) as it should. Have been constantly running it when driving car with bypass switch. Insulation near turbine is not a good design. Needs rethink.
After squashing duct further into crevice between fender and body (the first adjustment), there’s far less contact between tire and duct. Squashing duct further into crevice is not happening. Can see internal deformation of CEET duct in a post above. Contact as seen is acceptable for now. Were ride height of car a bit higher… would be no problem here. (Fender to ground = 23”.) Anticipated wear from debris being slung from tire onto system is absent---rubber "protection" looks as good as when it was installed but for water marks.
Intake duct is where it was last seen. Bypass valve is “exercised” on occasion by closing intake off with hand. Pitch of turbine returning as it was prior to blocking intake suggests valve closing fully. Filter’s clean.
Condenser’s outlet surface is undamaged. So too are surface areas facing tire.
Summer temps are coming on (in Miami.) Plan is to charge system towards end of this month---end of May (‘18). Looking for 90+ degree ambient to work in.
Karl ~
Old 05-15-2018, 03:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #223 (permalink)
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Head on over here and charge it, Karl - Friday's high in North TexAss is 98 (this place suuuuxxxxxxx !!!!)
PS - good to see you back and posting Kinky K!
Old 05-15-2018, 09:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #224 (permalink)
Discseven's Avatar
Thanks for offer RonO! Were I less occupied I'd be knocking on your door.
Yeah, been absent a bit. Getting back in saddle with AC.
Karl ~
Old 05-16-2018, 02:36 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #225 (permalink)
Discseven's Avatar
Having waited to charge system has proven fruitful---its allowed a refinement which would otherwise have been passed up now only to have been done later. Credit here to Charlie for tabling Spal idea a while back. Exactly how to blend a Spal into air-bucket concept has taken some time to sort out (because air-bucket remained an obstacle---in more ways than one.) Solution was simple once seen… get rid of air-bucket. Intake, filter, air-valve, duct and EDF (correct name for “brushless turbine”)... those parts remain installed. Premise now is to serve ahead-of-wheel air to Spal's intake side. Nozzle at end of EDF serves this air.
From outset when EDF was planned, blade survive-ability has been questionable. These blades now have 2,000 car miles on them. (By-pass switch allows EDF to be tested independently of AC working. Have run EDF all the time when car is driven since its install.) Thanks to Glen for these blades looking as well as they do---intake filter was his idea. Unit was “choke tested”---small leaves & twigs being fed intake with NO FILTER installed---pics lost. (I did this with back up EDFs on hand.) Is capable of producing fine mulch for a while. Eventually there’s too much material to process and stuff gets caught between tip of blades & wall... Motor stops/fuse blows. Clean out and reset fuse and motor's back. Rain/wet has been no problem. (Is brushless motor.)
12” pusher Spal going in. 1,292 cfm @ 0.0 static pressure. Input = 12.6 A. Edge depth = 1.10”. Center depth = 3.44”. Fit between this 14” x 12” condenser and 12" Spal in hand couldn't be better. Only mod here = drill 1/4” bolt holes in condenser's flanges. As this is going together, am not sure how unit will fit in fender space.
Spal’s blades... ringed---makes sense. Junction... will cut off and place bullets.
Another hole goes in chassis to run Spal's cable. Never fond of cutting into car like this. Visions of structure rusting (at these holes) and my son---who shall inherit this 911---... I see him cursing me for such tub/chassis violations. Am hopefully avoiding that distant angst in my Son... idea = put gel epoxy on exposed metal edges inside hole and into grommet’s seat before installing grommet. Surly better than nothing. Engine bay end of cable will get power from fuse panel near CDI (‘80 911 with ‘85 3.2). Believe top fuse is one to connect to. Don’t quote me on that---need to make sure. Relay to switch Spall ON/OFF is signaled from power turning compressor ON/OFF. 2nd cable running through bulkhead is for EDF.
Reason for bullets... heat shrinking. Have seen HS done with silicone put on electrical connections and heat shrink tightened from center outward to both ends---squeezing silicone out. Seems fine idea for more permanent junctions than this. Did not go that route here in order to maintain easy disconnect/reconnect.
New footers. Beef’d up (due to Spal weighing measurably more than bucket.)
Spal-to-fender’s skirt clearance. Am usually guilty of too-tight vs too-loose. Flex of car while driving will likely see this clearance go negative on occasion. Will keep eye on it to decide if mod is called for.
Clearance between Spal’s motor-house and fender-to-skirt seam. This measure is controlled by combination of unit’s tilt, footer height, lateral positioning, and front-to-rear positioning. Challenge here is parts are too large for space to start with---leaves very little adjustment making. Looking at this, Spal is 180 degrees wrong. Would have been better to place wires at bottom of housing instead of very near to fender's guillotine-seam. Is bad move. Return trip may be in order.
Karl ~
Old 09-03-2018, 02:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #226 (permalink)
Discseven's Avatar
Looking down at condenser’s exhaust side. (Engine bay is at left here.)
Looking up. (Engine at left.)
7”ish long nozzle is connected to EDF’s outlet. Bracket supporting nozzle bears little weight---most weight of duct & EDF combo is born by zip ties attached to rear lid release sheath. Connection of air-bucket to duct generated a number of complexities which are now gone with this config. This new direction genuinely qualifies as less is more program---a rare moment in this project.
Rather than angle footer to accommodate unit’s tilt, nylon wedge-washers were made (by melting down one side of washer.) Installed washers is not an exact compensation for tilt. Final wedge has yet to be made & installed. Was planning to put rubber washer between footer and strut as a pad but… even that small dimension causes a fit-conflict. Rubber is out. Putting footer between strut and fender flange… that too creates conflict.
Discharge extension pipe previously formed---to run parallel & behind strut… that run’s not happening now. Spal’s dimensions have forced entire unit forward so discharge port aligned with fender’s bracing strut. To move unit back required removing material from taillight assembly and from Spal. Those mods… too Frankenstein to bear for me. Was questionable they would even work. Path chosen is positioning unit so discharge port’s ahead of strut. Technically and visually this solution is not appealing. What is appealing here is it keeps things moving onward. (Abominable option = start over with smaller parts. Not.) This is way it is until next exploration. Discharge pipe… has rubber hose over it. If you look at bottom of vertical trim on mesh… bottom of unit has penetrated into wheel well’s arch. Azzuming I spent a good deal of time attempting to optimize new unit’s fit, here’s proof that 14” x 12” condenser with 12” pusher Spal (as used) is NOT an optimal fit into 911 SC’s fender cavity. Is not deplorable enough to demand a reinvention. Would this config fit 930 fender? Believe it would---everything could sit further back provided more "flare space."
System is closed.
Karl ~
Old 09-03-2018, 02:58 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #227 (permalink)
Porsche Crest
Keep GOING Karl!
ICECOLD911
Old 09-03-2018, 05:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #228 (permalink)
Discseven's Avatar
Charged yesterday. Am traveling next 2 weeks. Ran out of time to post results before leaving. Will attend when returned. (Look out RonO!)
Karl ~
Old 09-10-2018, 07:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #229 (permalink)
Discseven's Avatar
Done. Results are here: AC pressure & temp results from Arduino Digital Control and Air-Bucket builds
Karl ~
Old 09-30-2018, 05:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #230 (permalink)
