lifter type on a 3.2
I have an '85 3.2 and cannot find a picture or diagram in the Bentley manual of either the cam shaft or a lifter.
I want to know if the lifters are flat or roller. I think they're flat, but I want to make sure. Thanks. |
+2 Flat Tappet Type
http://cdn1.pelicanparts.com/catalog...43-02-M260.jpg aka Rocker Arm page 5 1985 Porsche 911 Carrera Targa - Cylinder Head & Valvetrain - Page 5 |
Thanks Bill and DRACO.
Therefore, I need to continue to use oil that has high ZDDP levels or is made for flat tappets. |
Porsche will be happy to sell you their own branded oil that is appropriate and comes in pretty metal cans! 😊 Has anyone found out who actually produces this for Porsche?
However, I assume that any of the high ZDDP oils would work just fine. |
1100-1400, if you can find it. EPA is forcing changes to kill our cars.
I am a little confused by the term Lifter. It is a rocker arm driving the end of a valve stem. There is no lifter like a hydraulic valve..., no?
I originally used the term lifter because I have seen on overhead cam engines with solid lifters a cylindrical shaped piece between the cam lobe and the rocker that provides a flat surface for the rocker contact surface.
It appears that on the 3.2, the cam lobe directly contacts the curved surface of the rocker. |
| All times are GMT -8. The time now is 02:17 AM. |
