3.6 valve cover question
Just got my package frompelican parts with valve cover gaskets, exhaust gaskets, and new clips to hold the wires to the block, After adjusting the valves do i need to apply anything to the valve cover gaskets silicone? or just grease, these are totaly different the 3.0's, ill have a up date this weekend on the project, I plan to adjust the valves tonight and start assembling the motor, Kevin
I have the same question. The 3.6 gaskets are really different than the earlier ones. My motor came with a silicon gasket sealer on the gaskets. I don't know if this is required or not.
EDIT: Kevin, here is a thread from Rennlist on the subject. They say no, and state Pelican advises to use the sealant.
.. Last edited by pbs911; 01-31-2003 at 01:12 PM.. |
Paul do you have a picture of what your 993 header gaskets look like, i got 6 o rings, i also talked to embs and i think i may try the 993 cat with no muffler, he says it sounds good and not to loud, Kevin
hallo Paul/ Kevin
Just use a little bit of Oil , if they are used some People use würth , but i would not . The Rubber seals by itself . harald |
Kevin, yes 6 metal o rings for the exhaust gasket.
Thanks Harald, that's what I was thinking.
I think the TRG headers may be acceptable for the track but for street driving / stop and go situations they build up a lot of heat. Also that slip fit deal with the super crapp mufflers really sucks, mine leak really bad no matter how tight they are. |
