Power Window troubleshooting
1988 911 Coupe.
The driver side works normally. Checked fuses anyway and it looks good. Driver side was working with a bit of a delay. Hold the button down (On the driver door) and then after 2 or 3 seconds the window would work. Now, there is nothing. No movement at all. I replaced both switches for the passenger door. I checked for any cut wires and can't find any back inside the passenger door. I pulled the connections to the motor and cleaned/replaced them. Any suggestions? If an electric motor is going would it delay movement like that for a second and then work at full speed before dying? That seems odd to me. Seems like it is some sort of a loose ground or power somewhere. Any ideas are appreciate. |
UPDATE: I banged on the electric motor a bit while holding the button down and the window went down. Going up it worked fine. I am guessing this points to a new motor? |
You can also apply 12V across the 2 middle terminals of the switch connectors.
The passenger window on my '88 does the same thing. Works well, but every once in a while I do what you did: bang on the door card just above the motor while holding the switch on & it'll go. I think it's a motor problem also. Can probably take it apart & grease it up, but it's easier just to bang on the door. ;)
P/W Motor.
remove the motor, clean the internal mechanical connections, and lube the motor shaft and the end with lithium grease. Gerry pm me as needed. |
| All times are GMT -8. The time now is 07:54 PM. |
