Topocalma
How to disassemble '73 foglights / lense change
I want to change the cracked lense (glass) on a 'through the grill' foglight of my '73 911. How do I change the lense, i.e. how do I disassemble the foglight?
Thanks for your help - I tried today but decided better ask the experts before messing sth up...!
Old 08-05-2017, 02:34 PM
Banned but not out, yet..
RSBob's Avatar
Once you have removed the light assembly from the car using an Allen wrench there is a single screw at the base of the assembly you will loosen. Then pry the two haves apart. The lense is held in place by tensioned clips. Take a picture of their orientation. Remove the clips carefully using needlenose pliers. Safety glasses wouldn't hurt. The lense will pop right out. Reverse procedure to install.
Old 08-05-2017, 08:23 PM
Topocalma
Thanks! It worked. I was able to access the screw without taking the light housing from the car.
And yes to the safety glasses... wholy s**t.
Old 08-06-2017, 11:36 AM
