Seatback recline spring grease
I've separated my sport seats, seat and backrest, from each other to redye. I am curious as to what type of "grease" is used to pack into the "clock spring" on both sides of the seat. It has some 30+yo heavy thick grease packed in there and I want to clean it up and replace it. Any ideas? That spring when the seat is bolted together is right up against the seatback and there was nary a bit of it on the leather. So the stuff stays in place.
There are springs on both sides and you can see the grease packed in there. ![]() This shows how clean the seatback is even though that spring will sit right against it.
Dan T '85 Carrera Dansk premuff/sport muffler 7's and 8's, Steve W chip Kuehl AC and fresh top end |
You know, there are some good dry lubricants around now days. If it were me, I'd clean the old grease out of the springs and use a dry lube on them. A dry lube can be easily reapplied in the future if you decide you want to. The grease is old tech.
Marv Evans '69 911E |
Which dry lube would you recommend?
Thanks Marv. I was thinking that a thick grease of some kind would be better suited for this compression type spring. Is the purpose to preserve the metal and keep the squeaks down? Would a dry lubricant do that?
