Oil tank clean out
I'm replacing my corroded oil tank with a good one from a junk yard. Any tip on how to clean the inside throughly before I install it?
1974 911 2.7L coupe with sunroof |
You might check with your local radiator shop.
1973 911T-working on 1964 Willys Jeep 1964 VW Sunroof Beetle a.k.a Fred 1973 VW Super Beetle-very nice 1999 Ford F350 Powerstroke |
Varsol, or Berryman's B-1 2 Chemtool ... rinse and shake, multiple times until no visible residue is prersent in drained solvent.l
Be sure to remove the oil filter mounting pad, and replace the sealing O-ring.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Team California
And if you take Warren's advice, be sure to wear a good respirator, (rated for the vapors in solvent used), and chemical resistant gloves, also rated for what you are using.
Berryman's, etc., takes approx. 4 seconds to reach liver upon skin contact. And it is extremely carcinogenic stuff. This is something that often gets overlooked on this board w/ guys talking about using 8 cans of brakeclean to wash engine, , and something that most pros are aware of.
Denis |
try the por-15 tank cleaner, they make a kit for motorcycle gas tanks that is perfect for oil tanks, the kit is about $25.00 but has a cleaner/etcher and sealer and also get a can of the black exterior paint
web site is: http://www.por-15.com/
1975 911S Targa Silver Anniversary Edition |
PRO Motorsports
Might be a good idea to have it ultra-sonically cleaned. You can never be too careful here. There is no filter between the oil pump and the oil tank.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
