Replacement coil?
I have been gone from this forum for a couple of years as I experimented in the water-cooled world. I am back now and looking to pick up a spare coil.
I did a search and looked through the parts catalog to see if anything new was available. I didn’t find much so I will ask: What is up in the world of coils? Is there a preferred route to go? Is the silver coil still a POS? Thanks for any and all help. |
Yes. The MSD blaster epoxy filled coil works with the stock bosch ignition boxes. Just peel the sticker off.
sent you a PM...............check it out.
Is the MSD coil ok to use if Pertronix is installed?
Also, will that work with the stock Motronic ignition in the 3.2 engines, too? |
Do not buy a silver one from Brazil
Is the MSD Blaster coil OK for the SC and 3.2 both?
There are alternative high voltage coils of new design / manufacture specifically designed for the Porsche CDI ignition.
Parts?lassi? makes a CDI coil that is very close to the original Bosch coil.
Replacement coil?
Finding a replacement for a 3.2 Carrera is a challenge. The SC with CDI coils is different.
I finally found a used original black coil. It is sad that a 30 plus year old coil is the best option for a 3.2 Carrera. |
8222, yes. Wouldn't use it on a 3.2.
| All times are GMT -8. The time now is 04:13 AM. |
