Tire Size help please?
Gentleman and Ladies,
I have some rubber on a set of Ruf wheels that I would like to put on my Euromeister Fake Fuchs while I get the Ruf's refinished. Ruf's R - 255/40/17 F - 235/40/17 Euromeisters: R - 265/40/17 F - 225/40/17 Can I put the Ruf rubber on the Fuchs wheels and what will the implications be to the car/size of the wheel? Oh, I have a factory M491 wide-body if that helps. I have some wheel rub in the front with the current sizes on the Fuchs (at lock). Thanks, Scott |
235/40 x17 wants a wheel 8 to 9.5" wide these all fit you car if the ET is corrrect 255/40 x17 wants a wheel 8.5 to 10" wide, again these fit when the ET is right 225/40 x17 are generally track only sizes, usually it's 225/45 x17 which want 7 to 8.5" wheel, fit still depends on ET 265/40 x17 want 9 to 10" wheel fit depends on ET if the ETs are correct and your widths are w/i the overlap spec you will be fine |
Really appreciate that Bill, Thank you.
Scott |
Bill, what does ET mean please?
Offset
https://members.rennlist.com/1976c38...0measures2.jpg |
Thanks Guys, got it. Scott
| All times are GMT -8. The time now is 07:22 AM. |
