Counterclockwise?
Does this transmission mount look right?
I don't think this gap is right.
Did I install the wrong mounts?
Old 08-13-2017, 12:09 PM
That's a G-50?
Old 08-13-2017, 12:14 PM
proporsche's Avatar
G50 has an alu cross-member..this is just looking fine..some people put washer on top and bottom some do not.Otherwise it is ok--Porsche say 2 per mount
Personally i only use two on bottom like yours
Ivan
Old 08-13-2017, 01:04 PM
Under the radar
Trackrash's Avatar
Mine originally looked like that. I added an additional washer to take out the slack.
If you are not experiencing any shuddering when engaging the clutch, you are probably OK as is.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-13-2017, 01:58 PM
Counterclockwise?
Having shifting irregularities. Sometime it goes into gear perfect. Other times needs some perswation. Rebuilt transmission and wevo shifter.
Old 08-13-2017, 03:18 PM
proporsche's Avatar
do you shift with 1 second delay or strait across ??
Ivan
Old 08-13-2017, 03:23 PM
Counterclockwise?
Ivan
Yes.
Doesn't really apply when I'm stopped and have to force it a bit into first.
Old 08-13-2017, 03:53 PM
proporsche's Avatar
yes to what?;-) if you have trouble shifting into 1st standing check you coupler adjustments and of course the clutch adjustments.
my guess is the coupler adjustments...
Ivan
Old 08-13-2017, 03:59 PM
Under the radar
Trackrash's Avatar
My point was in relation to starting out as you are slipping the clutch. If the mounts are able to move it could cause a shuddering or vibration resulting in uneven clutch engagement.
Shifting is another issue.
Gordon
Old 08-13-2017, 04:05 PM
Counterclockwise?
Sorry. Yes to 1 second delay.
I've been doing lots of adjusting.
The wevo is pretty easy because it centers well.
I'm concerned my rebuild isn't up to snuff.
Old 08-13-2017, 04:07 PM
Counterclockwise?
No vibration.
Old 08-13-2017, 04:08 PM
proporsche's Avatar
ok take it easy on your self..the rebuild...what did you do exactly?New synchro rings and what else?
Ivan
Old 08-13-2017, 04:12 PM
Counterclockwise?
I had a shop do the rebuild.
1st and second synchro and lots of other parts. $3000 in parts.
Is it possible to assembly the transmission and not have it perfectly line up?
Old 08-13-2017, 05:46 PM
#147 of 2096
If the problem is after your gearbox was repaired the problem could be that the energizer that was used inside the brake band was the incorrect one.
Don't ask why I know. LOL
Regards.
#147 of 2096
Old 08-13-2017, 05:56 PM
proporsche's Avatar
911 rod..it is not normal if this shop is a professional 911 shop.
Also it takes time before your synchro are broken in.How long ago was this done and did you contact them regarding this problem?
Ivan
Old 08-13-2017, 11:51 PM
T77911S's Avatar
not normal.
I do believe there should be another washer there.
it should also bolt all the way up.
I hope they did not cross thread the bolt. did you put a wrench on it?
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-14-2017, 06:14 AM
Counterclockwise?
I did the re and re myself. Had the rebuild done by a shop that I am not having communications with anymore (Unfortunate, but that is the way it is)
About 3,000 km since rebuild.
Bolts are fine as I have checked them a few times.
"energizer that was used inside the brake band" What is this?
I pulled out the old ones and they appear to be the same.
Another reason I am concerned is a certain corner at the track with a hard turn then a quick downshift I had problems finding 3rd. Not always even though my driving technique was the same.
Maybe I need the WEVO mounts?
Rod
1986 Carrera
2001 996TT
Old 08-14-2017, 06:27 AM
T77911S's Avatar
ya gotta keep the tranny from moving first off.
pull the tranny mount off. clean the threads on the bolt and the body.
put a washer in there
RACE CAR:: sold
Old 08-14-2017, 10:00 AM
Ivan
'Pregnant pause' sure, but 1 second? In one second you totally lose rev-matching...
I often have long gaps like that, but need to double clutch and rev match.
Old 08-14-2017, 10:18 AM
Counterclockwise?
Ya, more like a split second. The least amount of time you can.
So putting a washer between the body and rubber?
Rod
1986 Carrera
2001 996TT
Old 08-14-2017, 11:01 AM
