Check continuity in the wiring all the way to the coil. I had a wire break inside a connector on a car. It took a while to find it.
I made a Jumper wire long enough to go from the PCM to the coils to check. No continuity on #3, so I worked my way back until I found the problem. |
I jumped the DME such that the fuel pump and DME were powered directly from 30 (the battery) and tried to start the car, just to double-check. No dice.
With power to all coils, power to the fuel pump and DME, no hint of rough running at any point, and then a sudden failure...It sure points to the DME, right? I'll pull the distributor cap and test the coils, but if there's a way I can bench test the DME somehow...Well, it's easy to get to and sure seems like the culprit, even though I can't see any visible issues. I would be more systematic, but some things are much easier to verify than others...I also don't really know how the whole system works together. It seems to end with "at some point the DME spits out a spark pulse if conditions are right" but I don't know how to mock the conditions for which it would... Troubleshooting link: http://forums.pelicanparts.com/2892572-post13.html 1984 pins: http://forums.pelicanparts.com/uploa...1205355264.jpg 1995 pins: http://forums.pelicanparts.com/uploa...1330090864.jpg |
Have you checked the flywheel sensor. After all, the pulses from it "kick off" everything that happens in the DME ECU! A motor with a bad sensor would most likely show the same symptoms you have. just my $.02
I'm aware of three suspicious sensors: speed sensor, reference sensor, and cylinder head temp sensor. They all seem to be in rather tricky locations. If the wiring leads back to the DME harness, perhaps I can test them without taking anything apart...I just don't yet know how.
I'm armed and dangerous with a power supply, a multimeter, and a test light... |
system with sequential injection versus batch injection of a 3.2. Don't know what the exact readings should be on the flywheel sensor, but you need to test it with a scope of some sort to see the pulses. Perhaps there is a continuity test. Do some searches! |
Here's the procedure to check the flywheel speed/ref sensor.
http://forums.pelicanparts.com/uploa...1425789024.jpg |
Part of the fun is that my system is neither a 993 nor 911, so I have to do some adaptation of search results...
The price we pay for a bit o' electronically fuel-injected torque... |
Do you have fuel ? Is the fuel pump making its usual noises ? (don't know what that sounds like on a 3.6 but you should !)
Just wondering if that smell came in through the heater duct-in which case melted pickup wires
would shut things down. Anytime there's that smell there is melted insulation-somewhere. |
Here's the order of things that happen when starting a 3.6.
1. Ignition turns on the DME relay first section which turns on the DME ECU and applies 12V to the coils and to the fuel injectors. (you will measure 12v on each side of the coil as well as the fuel injectors) 2. While cranking the motor (at least 30RPM) the flywheel sensor triggers the ECU to energize the second relay in the DME relay to turn on the fuel pump. Also at this time, having synced the reference and speed pulses to the ECU, the ECU begins supplying the ground signals to the coils and injectors to activate them. Thus firing off the motor. While cranking your motor, have someone listen for the fuel pump to energize, that will tell you if your speed/ref sensor is working. |
I've had issues before where it was a result of something I did recently.
You just replaced bushings in the rear of your car correct? Check the routing of your harness between the DME and the engine. Something may have gotten bumped or burnt. Just throwing it out there. |
This is all helpful, thanks! So:
- The DME relay behaves properly outside of the car. - The DME relay socket has good ground. - The DME relay socket has 12v on pins 30 and 86 with the ignition off. - There is 12v to the ignition coils. - Test light flashes on the ignition coil inputs while cranking (barely). - The fuel pump kicks on while cranking. - No visible indication that the Motronic DME is fried. but no spark. Current theories: - DME is toasted somewhere. - Both ignition coils are toast. - Some combination of problems (one dead coil, broken distributor belt). I wish my test light flashed more prominently during cranking on those ignition coils...I'm not certain it's not just power fluctuations due to load. That said, according to the post from uwanna, my fuel pump wouldn't spin if the speed/reference sensors weren't good, sooo... It sure seems like the DME is toast, but it's friggin' immaculate inside. I'm gonna find a way to test the ignition coils and put an eyeball on that distributor belt. |
I realize there need be no visual indication for a circuit board or chip to be bad, but damn. Opened it back up, pulled up the little white pin insert to allow the board to pop out of the case, and got shots of both sids this time.
http://ensaster.com/pics/vehicles/sm...n/dme-clip.jpg http://ensaster.com/pics/vehicles/sm...wn/dme-top.jpg http://ensaster.com/pics/vehicles/sm...dme-bottom.jpg http://ensaster.com/pics/vehicles/sm...n/dme-chip.jpg |
In terms of recent work...In the last 100 miles I've done the rear suspension bushings, added front blinkers, a fan, controller, and relay, swapped out the temp gauge, installed a handbrake and heater controls...I supposed I could have jostled something, I just can't think of what. There's certainly nothing obvious from the outside.
To make sure your injectors are pulsing you need to attach a "noid" test light to one or more of the injector plugs. Was just at my local O'Reillys store this morning and they have a set of 6 NOID lights that you can borrow from their loan tools.
...Progress? A hot tip on Rennlist pointed me towards the existence of an external ignition module for this motor. If it wasn't bad before... I think it is now. I found this under my seat, resting on metal after some interior work. I guess it got detached, and since it was under the seat, I didn't notice.
Current (hopeful) hypothesis is that it was bouncing around, metal moved inside, and it shorted itself out...But I would think that the ignition coils wouldn't flicker my test light if this thing was the real problem, right? One edge of the metal plate was detached, so I gave it a bit of a tug and it came apart. What a weird piece of electronics. It smells a bit burnt, but it also might just be the peanut butter smell of all the gunk this thing is coated in. I guess I'm waiting on parts, now. http://ensaster.com/pics/vehicles/sm...ion-module.jpg |
could have possibly damaged the ignition output driver circuit in the DME ECU. Before installing new parts I would try to test the ignition output circuit using the procedure below. If you don't have a scope, maybe you could use an LED test lite to check for the pulses. Just a thought. http://forums.pelicanparts.com/uploa...1314133733.jpg http://forums.pelicanparts.com/uploa...1314133751.jpg |
Well. It was the ignition module (I believe there was only one in 1995). Kind of. I bought a new cheapo ignition module, the car leapt to life, and I howled like a maniac!
Then about two miles down the road, it died suddenly again. I pulled the ignition module and it was hot. Like crazy hot. Almost burned my hand. I let it cool down, but the car won't catch. I assume this one is toast too, or was no good to begin with (though that seems unlikely based on the circumstance). So. There is clearly a condition that is frying the ignition module. What could cause that?? |
993 was the same. You do have two coils and twin plugs, correct? Wonder why 993 uses just one ing module. Inquiring minds want to know! |
| All times are GMT -8. The time now is 10:28 PM. |
