-   -   My airflow sensor stop is loose (http://forums.pelicanparts.com/porsche-911-technical-forum/966834-my-airflow-sensor-stop-loose.html)
dino_jr 08-17-2017 09:41 AM
Hello.
My airflow sensor stop is loose and rattling around:
http://forums.pelicanparts.com/uploa...1502987843.jpg
See this pic... The red and green screws spin but do not tighten... Do I have to remove the Air intake boot to get to the top sides? Do my blue and orange arrows point at Nuts not shown in the pic for some reason?
Thanks.
Jameel 08-17-2017 10:08 AM
It's going to be a tight squeeze, but I think you can probably get a wrench between the air box housing where the filter sits and the back of the air flow sensor . You should be able to get to the top of your green and red screws without removing the boot. The nuts pictured in the schematic are there (see the top of your red arrow) The rear screw has a washer and nut on top of the air flow sensor, the front screw has the same, but the nut sits in a little hex well inside the plastic connector for the AFS electrical connector.
Some pics of the nut and connector (your blue and orange) in this thread. You can see one AFS has the stop installed, one doesn't. http://forums.pelicanparts.com/porsche-911-technical-forum/948070-can-i-use-air-sensor-plate.html
dino_jr 08-17-2017 11:26 AM
Fantastic thanks Jameel, I'll try this later... the link to those other pics is just what I needed.
