poobala's Avatar
terms
I don't no what these terms refer to or how they help can someone explain ?
shuffle pinned
Knife edged crank or block
boattailed
Old 02-03-2003, 06:32 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I haven't built any motors (yet ) Shuffle pinned means that you put pins above (and below?) the main bearings so that at high rpms the 2 sides of the case done slide against each other, keeping it more stable.
Boat tailing is where you round some of the reinforcement within the engine so that air will move better within the case. It's supposedly good for about 10 HP according to Bruce A.
Just what I've learned from BA's book
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-03-2003, 06:44 PM
Senior Member
Superman's Avatar
Knifing a crank means trimming the counterbalancing lobes so that they produce less drag as they pass through the pool of oil in the sump. Since your engine is a dry sump system, this is not particularly important.
Mocha 1978 911SC. "Coco"
Old 02-03-2003, 06:56 PM
