Which washer on Chain Tensioner Oil Lines?
Anyone know which washers you use on the oil lines that run from the cam to case. It is the line you replace when you install the updated tensioner kit. The lines (2) come with the kit.
Should they be aluminum or copper?? thanks |
They were Al in my kit.
Colin
993 |
either will work. the copper is better, IMO, because it doesn't squish as easily. they're also used for fuel connections if that means anything.
Copper Washer question
The copper washers I have are a bit smaller in diameter than the the oil fittings.
Will they still be okay?? |
