-   -   Torkspec website (http://forums.pelicanparts.com/porsche-911-technical-forum/966960-torkspec-website.html)
3Ddesigns911 08-18-2017 10:24 AM
Torkspec website
I just found this site and I wonder how accurate it is. Is anybody familiar with it? What's nice about it is that is shows not only the torque values, but the bolt sizes including the ratings which the part catalogue does not. ... again I wonder how accurate. So far the only way I have been able to tell the strength of the bolts is to read the numbers on the originals, but it would be great if this site shows it correctly.
Porsche 911 Torque Specifications - TorkSpec - Knowledge for the Motorhead
Dmitry at Pelican Parts 08-18-2017 12:32 PM
Do you have a workshop manual with the torque specs listed to compare to the site? If not, I would suggest grabbing one for your 911 - depending on the model, a Bentley manual may be available.
Bentley Porsche Repair Manuals - PelicanParts.com
Mark Salvetti 08-18-2017 02:47 PM
Well, checking the specs for a 3.0 L engine, it states that the torque for the connecting rod bolts should be 15 N-m.
My Porsche Little Spec book says 50-55 N-m. That's a pretty major bust.
Mark
yelcab1 08-18-2017 02:57 PM
Mark
If you are rebuilding your engine and torque your rod bolts to only 15Nm, then you have no business rebuilding your engine.
3Ddesigns911 08-18-2017 06:05 PM
Yes I do have the Bentley as well as Wayne's books, but never compared them... thought I'd ask first. I guess it's no good...
Thx guys
john walker's workshop 08-18-2017 07:19 PM
It says 15nm plus 90 degrees if you look at the note.
adias 08-18-2017 07:29 PM
Check several sources. Bentley has errors too.
Mark Salvetti 08-18-2017 08:24 PM
You're right John, I missed that. Good point. Still different than Porsche's specs, maybe OK?
The point is that you can't trust an unknown source for something this important. If you have to double-check every value, then what good is it?
I'm sure there are typos in the printed manuals as well, but hopefully by now they are known and not hard to find.
Mark
