911 3,2 front fender convension
Is it possible to install the Euro rubber on a US front fender (where the US turn light are)?
If so, what is the part number for left and right side front fender rubber?
Old 08-23-2017, 03:41 AM
Flojo's Avatar
it is.
access is an issue without removing the bumper as you'll encounter:
a) oil cooler to the right beeing in the way
b) water tank to the left beeing in the way
Part No:
left 91150530700
right 91150530800
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 08-23-2017, 03:58 AM
Originally Posted by Flojo View Post
it is.
Part No:
left 91150530700
right 91150530800
Agreed; bring patience and Band-Aids for your fingers, and you can do it without removing the tank or oilcooler (but removing the brace that protects the oilcooler may be required). Good luck.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 08-23-2017, 05:37 AM
it is.
Part No:
left 91150530700
right 91150530800
Old 08-23-2017, 06:08 AM
Eng-o-neer
Tremelune's Avatar
I bought two clean ones on eBay for $50/ea from mattman1955:
NICE USED ORIGINAL PORSCHE 911 912E 930 FRONT BUMPER RUBBER SIDE MARKER DELETE | eBay
NICE ORIGINAL PORSCHE 911 912E 930 RIGHT FRONT BUMPER RUBBER SIDE MARKER DELETE | eBay
You can do the swap without taking stuff off if you can reach up from under the front valance. The stock sidemarkers they will replace are worth more than $50/ea.
Old 08-23-2017, 09:54 AM
