Tread size of CIS injector head ?
Wondering if someone knows the thread size/pitch of the course thread CIS injector head used on a 3.0. Yes I could take the time to match and compare to figure out etc. but if someone already knows all the better time saver for me ... I will have some time tomorrow to make an injector puller and was gonna use a cinch nut threaded onto some threaded rod with a nut, washer and 3/4 inch I.D. copper tubing ….
Injector fuel line connector thread is 12mm 1.5mm pitch.
… thanks Mark - dave
… ended up buying a 1/2 inch by 13 pitch nut but turned out did not need to use my setup as the injectors pulled out by hand with a 12 mm thread cleaning nut out of my tap kit threaded onto the 12 mm thread head of the injector … so just used that as a grabber so I could just pull th injectors up and out ...
| All times are GMT -8. The time now is 09:34 AM. |
