911 Mania
Originally Posted by Tremelune View Post
I've never liked the word "outlaw" to refer to a slight deviation from a niche purist's vision of ideal...None of these cars are outlaws, and Magnus Walker doesn't need anyone to bolster his brand for free...
Guessing most already know the Outlaw theme started with Rod Emory and his 356's, not Magnus. Easier to understand when applied to 356's as it was unpopular to deviate from stock. How many hot rodded, upgraded or outlawed 356's do you see compared to 911's?
Like the bottom right and rectangular middle. Keep up the steady progress. I too have a middie, but am only in the information and part collecting phase. Thanks for your posts, enjoy learning and watching your progress.
Hemmingway said it best, There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
Old 10-03-2017, 07:52 PM
Eng-o-neer
Tremelune's Avatar
Tis the same. Someone was modifying cars, some other people got annoyed about it, and a marketing buzzword appears. It mostly bothers me because people have been modifying classics for decades and suddenly if you do it to a Porsche it's an outlaw? It always struck me as a pretentious term for car that has simply been modified.
Then again I still hear people argue over the pronunciation of a word that can't exist in the English phonetic system, sooo...
Old 10-04-2017, 10:57 AM
grateful user
don gilbert's Avatar
If that tail is the real deal, you could fund a lot of parts for that car. Few grand, maybe more nowdays.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 10-04-2017, 03:28 PM
Munky King's Avatar
Thanks for the kind comments and inspiration
Don, As the tail is not really in the style of where I'm headed it will probably find itself in these hallowed pages if I don't end up using it as garage wall art.
I can't read these comments at work, but luckily I think we are on the same track...
I had a play on CAD with the general idea and came up with these
Will take on board the comments and suggestions and try a few more tomorrow.
Thanks so much for the input!
Old 10-04-2017, 05:14 PM
Munky King's Avatar
Managed to put this through on a big print today as part of a plastic test piece for the future stainless part. Looks like it came out okay.
Not a big fan of the color... but I'm going to put an order in for the first side now in stainless. Once it's here, I will see if there are any changes needed and make a mirror twin of it for the other side of the car
Old 10-05-2017, 05:50 PM
Munky King's Avatar
SC style...
Had a couple of packages waiting for me when I got home late last night.
Didn't get to open them as I had a tired 8yr old to put to bed!
Old 10-07-2017, 04:17 AM
Munky King's Avatar
Aaaaarrrgghh. Damn clutch pin.
Need to wait until Monday to borrow a press!!!
Old 10-07-2017, 05:07 PM
I drilled mine out.
Old 10-07-2017, 06:56 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
The correct size pin punch and a large vice to support the pedal, and that hammer should do the job.
Gordon
'71 911 Coupe 3,0L outlawed
Old 10-07-2017, 08:22 PM
Munky King's Avatar
Thanks. I'll give both things another try tomorrow.
I bought a punch especially for the job. I've been thinking I should invest in both a big vice and a pillar drill for a while. Perhaps this could be the final excuse!
Old 10-07-2017, 10:30 PM
AND dont forget the Dremel that was advised back in post 41. It is an incredibly useful tool for a restorer.
Old 10-08-2017, 04:30 AM
Registered Minimalist
75 911s's Avatar
Flip it over to the unmolested side. Place on the floor and place the clutch on a 4X4. The wood will absorb some of the impact and make the pin take a lot of the force. The punch end should be the same size as the pin.
If you try to drill the roll pin, you may break off drill bits inside the pin itself. As it is rolled steel, the bit ends snap off inside the roll pin. Once that happens, you are trying to drill out hardened drill bits as well. :-(
lastly, you might try a little Kroil, pb blaster on the pin as you are punching it out. Good luck!
One more thing - line up the punch perfectly, grab a mini sledge (on second look I think your hammer is sufficient) and watch the top of the punch as you strike it with the sledge so you don't break your hand. Max strikes and that will drive the roll pin out. If you are tap tap tapping with that little hammer, you'll smoosh the end up and wedge it in there.
Duane
http://forums.pelicanparts.com/porsche-911-technical-forum/878569-born-75-me-my-new-911s.html
Old 10-08-2017, 08:18 AM
Munky King's Avatar
Thanks everyone
***BREAKING NEWS***
Big hammer 1, amazingly strong roll pin 0!
In the end, drilling the center of the pin to find a strong location for a punch (killing the edge on two drill bits) and then big hammer seemed to do the trick.
Wish the whole car was made of the stuff. Wow, that really was fun!
All drilling performed with an exceptionally helpful Dremmel hand tool too!
Didn't stop me from ordering a drill press and the vice of my dreams last night
Old 10-08-2017, 09:42 AM
Munky King's Avatar
Old 10-08-2017, 09:44 AM
Munky King's Avatar
Well my bargain window latch turned up.
I now know why it was so cheap!
At least I now have enough parts to copy to make a new pair for myself.
Think I will be making the screwed in, three screw section out of stainless too, as this one looks like it has the pox!
It makes the one I do have look good!
Old 10-09-2017, 09:48 PM
Under the radar
Trackrash's Avatar
FWIW, Stoddard has new latches.
Gordon
Old 10-10-2017, 08:32 AM
Munky King's Avatar
Trackrash - thanks for that. $125 isn't too bad all things considered. I think mine will probably cost me something similar to make in stainless. That could be the painless option...
Old 10-10-2017, 07:12 PM
Munky King's Avatar
Soooo excited.
New toy arrived. I've wanted a decent vice for years and finally have one
Complete with photobombing Dremel to prove I have one too!
My wife wasn't as impressed, when I dragged her out to the garage to look at its assembled majesty!
Old 10-11-2017, 06:05 AM
DerkPerk's Avatar
Did she give you the wrapping paper to wrap it back up for Christmas???
Looking forward to your progress and maybe a first hand peek. Looks like you live on the west side of town?
Old 10-11-2017, 10:31 AM
Munky King's Avatar
So true! The place where they used to make the Tonka toys.
The other thing is part of my garage counter cover clutter.
I've found in a shared garage (with wife and son) that any clear surface, such as a workbench, soon becomes populated with all sorts of stuff that was nothing to do with me.
Where as, an already covered counter, gains much less... so I've worked out if I put big but easy stuff to move on there, it has less stuff put on it and it's easy to clear as the clutters only intention is to clutter and be easily moved.
The Christmas paper is actually one of those useful icey Day windshield covers. Big, easily moveable. Never been on a car, but it's VERY useful
Old 10-11-2017, 06:02 PM
