Steve F's Avatar
Thumbs up
Very nice Try putting a mandrel in the bottom and chuck it your drill press, instant polishing machine
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP
Old 01-01-2018, 07:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Jonny042's Avatar
Hey thanks for the compliments. From what I've seen you've got every talent required for bodywork - basically all it takes is vision, a bit of research, and a lot of sanding. And sanding. And sanding. And sanding takes time, so you need a lot of that too.
Minnesota! We are practically neighbours! It's GD cold here too. Luckily the shop has a decent furnace.
Originally Posted by Munky King View Post
I've just run through your thread and I'm in awe of your bodywork capabilities!
I'm going to have to farm mine out.
This is Johnny's thread to those who are interested in his weight saving:
Project Heavy Metal - an all steel classic, remastered
You chose the best color though. I'm struggling between signal orange and white. I think white may win the day. I don't want a car that shouts 'race me'. More one that can surprise a few people at how fast an old 'un can go when it hitches up its skirts. I'm staying narrow body too, so no other real indicators of any turn of speed.
I finally pulled the new alloy rear out of the packing (thanks again Santa) and took a few pics.
It's dropping to -34 here in Minnesota today and even though the garage is heated, the heater can't keep up, so little progress expected here.
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The AX Beater
Old 01-01-2018, 08:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
Munky King's Avatar
I'm envious of your furnace. My little heater just can't keep up!
It would be great to meet up at some point. My car is a couple of years off from finishing though!
In the meantime, I'll keep an eye on your thread for hints and tip.
Old 01-01-2018, 03:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Munky King's Avatar
That's a great idea! Thanks.
I just need to brake the freezing cold conditions (in the garage) and give it a go.
It can't stay this cold for longer can it?
Old 01-01-2018, 03:12 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Munky King's Avatar
Quick pic comparing the two latch covers.
I somehow managed to get the two pivot centers slightly off... there was also a little shrinkage that I need to account for in the next version.
You can also see the arc centers for the back arch are slightly off. Nothing that can't be fixed on the next run though!
The odd color is down to the effect of the light - making the unpolished stainless part look almost golden! I think that means I'll have to make the set of all parts to keep the final colors consistent, though a quick polish with a spare bit of high grit soon changed the color back to that of the gear knob. .
Old 01-01-2018, 03:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
Munky King's Avatar
Originally Posted by rwest View Post
Those parts are cool Munky, hope you get the car on the road by summer.
Best,
Rutager
Thanks Rutager, but I don't think I have a snowballs chance!
Sooo much to do.
Have you managed to get your backfire issue sorted yet?
Old 01-01-2018, 03:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
Sooo much to do.
I finally diagnosed it and even took the Bitz setup out for a five mile drive this fall and I was impressed with the initial results.
Had a foreign object in #5 cylinder that bashed the heck out of the piston, I presume the exhaust valve and bent the plug grounding electrode into the tip. Once bent back, it no longer backfires, but my leakdown out the exhaust is around 60 percent; clearly I have damage!
Going to pull motor this month and try and do a budget repair if possible just fixing the bad cylinder.
Luckily, when I built the garage I went with 2x6s and lots of insulation, so my heater can keep up, although being electric, it rough houses my wallet a bit!
Best,
Rutager
Rutager West
Old 01-01-2018, 04:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Jonny042's Avatar
My furnace broke down a while ago and while I was fixing it I picked up a 4800W construction heater which seemed to work pretty well to take the chill of pretty quick. I figured it was a good idea to have a backup, not only for the shop but also for the house. We have a gas fireplace but this would add a bit more heat in the basement and probably keep us from freezing to death!
It would be great to meet up. I've been wondering if there are any good 911 centric events in the twin cities area - all I know of are the Nordstern PCA events. My car is a long way from being finished as well, but I do have a few others to play with. Which is of course one reason mine is taking so long to complete!
Old 01-02-2018, 05:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
AirBorne!
subscribed
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1970 3.0 PMO from a 1975S - Roxanne, 1970 911T widebody w 3.0 and megasquirt - sold to a great home to be reborne as a 911 ST, 1967 912 soon to become 912/6 with a 67s motor, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 01-02-2018, 06:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Munky King's Avatar
Well it's taken me a heck of a long time to get back out into the garage, but I was really cooking last Saturday evening (and then a neighbor came over with beer - and I didn't want to be rude...) but managed a few minor jobs before hand.
After doing a bunch of reading, I decided on the lazy mans way of cleaning some of the pedal assembly up.
A quick dip in this...
Followed by a swill around in this...
Turned this crusty piece of metal...
Into this not so crusty piece of metal!
Now with the old broken bolts drilled out and new ones welded in, it's just about ready for a light rub down and paint.
I'm amazed at how well the rust has been eaten. Especially as I specifically chose the second evapo-rust stuff because of its minimal environmental impact.
Need to get to work on the rest of it now!
Baby steps!!!
Old 02-13-2018, 05:42 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
DerkPerk's Avatar
Glad to see an update from you Munky. Gonna be 40 here today, open those doors up!!!
Old 02-14-2018, 07:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Munky King's Avatar
Glorious here the past few days. Seeing temps above freezing always cheers me up!
To garage is bearable again, so hopefully get some work done tomorrow!
Old 02-17-2018, 04:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Munky King's Avatar
Help!
Can anyone tell me, how much of these two parts should be painted before assembly?
Obviously I need to remove and replace the nylon bearings, but I'm not sure if all the metal parts should be painted or the tubular sections left but covered in grease?Thanks!
Old 02-18-2018, 12:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
Munky King's Avatar
These parts in blue:
To paint or not to paint, that, is the question...
Old 02-18-2018, 01:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Just paint the ends - not the shafts (just as you have it masked).
Old 02-18-2018, 07:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
Munky King's Avatar
Thanks, I guessed as much from the pitting, but wasn't sure.
Thanks again for the pointer!
Old 02-18-2018, 08:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #116 (permalink)
Munky King's Avatar
A quick lick of chemical resistant paint later.
Wow, I really should clean the bugs off the garage window sill...
And some flashy new Pelican parts waiting for the paint to dry.
Old 02-19-2018, 05:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #117 (permalink)
Munky King's Avatar
Still cleaning up the foot pedals. Next I need to buy a Zinc plating kit, before final reassembly.
In the meantime, I've started to work on another little problem... the key that came with the car doesn't fit a single lock. Typical estate sale nightmare sooooo
I've started to remove the ignition switch to see if I'm lucky and it has the paper with the key code on it. If not, to send it away to have a key match.
The steering wheel was in the way, so that came off.
Removing the breakoff bolts and setting about the pinch bolt at the steering column, I took off the lower column cover and the drivers side kneepad. Seems to go on and on.
Then I found this wire just hanging out.
It's a real long shot, but does anyone know what it is or where it should go PLEASE!
Thank you!!!
I still have this little lot to sort out as well!
But thoughts on that first brown wire would be very warmly received and appreciated!
Thank you!!!
Old 03-06-2018, 07:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #118 (permalink)
Munky King's Avatar
So huge thanks have to go out to the following Pelicans -
Timmy2
Xbmwguy
Kees
Sugarwood
Thanks so much for your help in my 'What wire is this?' Thread.
I now know where I've accidentally unscrewed the wire from!
Thanks so much guys
It's help like this, that makes it possible for an isolated dullard like me to attempt this stuff!
Old 03-09-2018, 03:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #119 (permalink)
Munky King's Avatar
In other news, today I was helped out by another member of the Pelican /Porsche community.
Stand up Kevin from GAS Motorsports in Upland CA. It's amazing to think that another Porsche guy that far away has been good enough to help an old Englishman out, all the way north in Minnesota!
Today I had a couple of packages arrive via GAS Motorsports...
I'm like a kid at Christmas.
I can't wait to open the boxes and peer inside, but I know when I have the surprise will be over, and the anticipation is quite a buzz!!!
Old 03-09-2018, 03:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #120 (permalink)
