Gas smell
Have a gas smell coming from somewhere in the engine bay does someone have a diagram of gas flow so I know where to check
What year of car?
DO NOT START THE CAR. look on the left side inner fender in the engine compartment for leaks around the accumulator and filter. check under the car at the tunnel for the fuel and return lines.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
1988 911 cab
When mine has gas smell in the engine bay, I found the leak was at the little J hose back near the firewall, toward the left.
Fat butt 911, 1987 Last edited by rnln; 08-25-2017 at 03:59 PM.. |
Jumper the fuel pump fuse or the DME relay to pressurize the system to help find the leak. Will allow you to help find the leak without throwing electrics thru the engine which may cause a fire.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
I know a common area that needs to be checked is the gasket to the fuel sending unit.
88 Carrera, Guards Red
88 ? really. you have to change the fuel distribution hoses that go to the injector rack ,regardless of whether that is actually the leak. they will be hard a rock and probably leaking. Or, you could just drive around with a fire extinguisher between your legs..
