-   -   Removing CIS (http://forums.pelicanparts.com/porsche-911-technical-forum/9679-removing-cis.html)
Seth Slovik 10-27-2001 07:09 AM
Removing CIS
I would like to remove the CIS (actually the whole intake system) on my 82SC to get to few leaks on the back of the motor and do a general clean up of the engine and engine bay. How difficult will this be to do with the engine in the car. I have no A/C so it appears that I may be able to remove it from the manifolds on up mostly intact, is this right? I do not want to pull the engine as I don't have the space or the inclination. Any help would be much appreciated.
Thanks,
Seth
rstoll 10-27-2001 07:49 AM
Unless you are a young contortionist, it would be easier to pull the engine. At least a partial drop.
Robert Stoll
83 SC
83 944
rattlsnak 10-27-2001 07:31 PM
Its actually quite easy on the SC models. 12 intake bolts, 2 fuel lines, unplug harness, throttle linkage and 3 air flow box bolts. Comes out as one big assembly. 30 minutes.....
Seth Slovik 10-28-2001 05:00 AM
Thank You Rattlesnake, It appeared that way but I thought there might be more to it. I have no A/C system and a backdated heater system so I seem to have very little in the way.
Thanks,
Seth
Clark Griswald 10-28-2001 07:47 AM
I've done it in the car. It can be done, but it does take some contortion.
You will need to drop the engine down, easy to do with a hydrolic floor jack. Take it as low as you can without pulling and wires.
Pulling the engine is not so easy if you don't have a lift.
