What kind of Headlights do I have?
The headlights on my 86 are really weak. Is upgrading to H4 the way to go?
How much can I expect to spend? I see some on summit racing for $50 and then some on host or eBay for $300 plus? What's the difference?
I would like to find some with black retaining rings.
Thanks!
Old 08-26-2017, 07:19 PM
Text me.828-230-0788
Joe Bob's Avatar
They look like euro H-4s. But it depends on the reflector, city lights and a few other issues.
Best to open them up and look at the bulb wattage.
You can bump them up and use relays to increase output. Also saves your headlight and H/L beam switch.
Are you in the US or other where?
Lot's of threads on the subject......
See me for graphics. www.nbdVINYL.com 83 cab, backdated with 3.6 I want a Porsche fix until I die. 2012 Mercedes ML350, 1980 Suzuki GS 1000S
Old 08-26-2017, 07:40 PM
thanks for the quick reply. I am in Texas.
Where would I look to see if a relay was already installed?
Old 08-26-2017, 07:54 PM
Good question on the relay. If those are the stock lights, I think it's doubtful the previous owner installed extra headlight relays. I'd check around the area of the fuse box to see if you have extra, non-stock relays tacked on to the wiring.
Old 08-26-2017, 08:01 PM
Joe Bob's Avatar
Get a Bentley Manual and search on H4 threads.....don't break them they be expensive....
H4s are NOT US delivery. Back in the day they were sealed beams....and they sucked.
You have an upgrade, just make sure it was done right.....
Old 08-26-2017, 08:06 PM
FYI
Just disassembled one of them. They are H1's. I could clearly see two bulbs once I got in there. Another clue was the 4 adjusting screws once I got the outer ring cover off.
I have read a few threads about upgrades and it seems some people like H1 and some people like H4.
Is one brighter then the other? Mine are certainly puny
Old 08-26-2017, 08:36 PM
H1 headlights are more fiddley to adjust than h4's, as the high and low beams need to be adjusted separately
Both (like modern headlights) have sharp cutoffs at the edges of their lighting patterns and need to be properly aimed to be effective ( bright at night)
You can roughly check how they're aimed by shining them up against a wall at night. With the car on a flat surface and, say, 15 feet from the wall, the headlights (low and high) should project a straight line, parcel to the ground (the upper beam cutoff), that's roughly the same height as the headlights
If they're not, aiming may be the culprit
Old 08-27-2017, 03:05 AM
Shaun @ Tru6's Avatar
With the clear top lenses, those are H1s.
Tru6 Restoration & Design
Old 08-27-2017, 04:14 AM
PCA7GGR's Avatar
H1 housings/bulbs w/ H4 lenses.
Sergio
PCA - 36yrs / Ex-RGruppe #197
'04 GT3 Halloween/SF Giants car
'11 E550 Coupe (Königstiger)
Old 08-27-2017, 04:23 AM
Thanks for all the replies.
Next question: Should I go to H4's?
Old 08-27-2017, 07:38 AM
Which could be part of the problem-- lens is there to focus the light emitted from the bulb - the single filament h1 bulbs (each headlight uses a different h1 bulb for low or high beams) are positioned differently than the h4 bulb (each h4 headlight uses a single dual filament h4 bulb for both high and low beams)
-- therefore, a lens designed to focus the light emitted from a single bulb will work right with two bulbs housed in different locations (short version - u need a properly aimed h1 lens do each headlight to make em bright and work right) -- get a pair of h1 lenses and u should be all set
Old 08-27-2017, 08:08 AM
clean the reflectors really well.
Old 08-27-2017, 08:14 AM
The lenses have clear tops which means they are H1s.
H4s have dimpled tops.
Old 08-27-2017, 08:48 AM
Vintage Owner
Jack Stands's Avatar
Matching the correct front lens with the correct headlight assembly would certainly help I'd think. Higherwattage bulbs would be brighter, but the relays and cleaned grounds would also be good ideas.
Check The Danial Stern website for lots of good info on lighting.
84 Targa
70 914-6
73 914-6 2.7 conversion (sold)
75 GMC Motorhome
Old 08-27-2017, 10:12 AM
Formerly known as Syzygy
Canada Kev's Avatar
In addition to that, H4s typically have H4 imbedded in a small square section of glass in the centre of the lens.
Also notice the difference in the fluting between H1 and h4 lenses below.
H1
H4
Kevin
Old 08-27-2017, 11:48 AM
SWS911's Avatar
Those are definitely H1 headlights. Is the "BOSCH" lettering "raised" on the outside or is it inside?
H1s are a PITA to get right, lined up, but when you do they are the best!!!
Old 08-27-2017, 07:20 PM
Thanks for all the replies. I definately have H1's. Anyone recommend a good brand lamp to install?
Old 08-28-2017, 10:32 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
If you install 100 watt high beams and 80 watt low beams you will be amazed at how bright they are...
IF you, as mentioned, install relays, AND make sure every electrical connection is good.
I found that there are connections on the BACK of the fuse block that were corroded in my car. Almost burned up my fuse block when I went to higher wattage bulbs. Those antique fuses in our 911s are also a place where corrosion can lead to resistance. AKIK.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-28-2017, 10:44 AM
I installed these Phillips Xtreme Vision +130 bulbs in my H1s. Absolutley love them. They are the highest rated bulbs by the CandlePower forum.
https://www.amazon.com/Philips-X-treme-Vision-Headlight-Bulbs/dp/B00QJWTQOE
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-28-2017, 10:56 AM
