daltvater's Avatar
Atom G4 Avation to Pump Gas Conversion
Question from a clueless person.
I have a 1979 running a 1995 3.6l with 50mm PMO's. Car is running aviation fuel at the moment but I need it to run 98 octane pump gas.
Wondering what I need to do to make this work?
Would I damage the car if I drove it with 98 gas temporarily?
Thanks for the help! Heres the car...
Old 08-27-2017, 09:18 PM
Just adjust the ignition timing for 98 octane fuel .
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-27-2017, 10:58 PM
daltvater's Avatar
Thanks Steve. Just to be clear that needs me to tune the ECU correct? I'd love to do that myself and not screw around with a dyno tune.
Old 08-27-2017, 11:03 PM
daltvater's Avatar
With your PMO carburetors, the ECU will not be controlling them like Injection.
So that only leaves ignition. So I would retard the spark (as suggested above by Steve) and put in a new set of 98 Octane friendly spark plugs.
Old 08-28-2017, 01:26 AM
You shouldn't need any new plugs (unless you are running the wrong heat range), but you will need to remap the ECU, if you are still using the Motronic to control the ignition.
There are options for doing that, however I cannot offer anything constructive without knowing the Bosch numbers on your ECU.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 08-28-2017, 07:13 AM
Av-gas is not suitable for (race) car engines! Av-gas is meant for slow revving aviation engines. Av-gas has a slower flame front than regular pump gas or race gas. 110 octane Av-gas is not the same as 110 octane race gas! Can you get 98 octane gas on regular gas stations here in the US?
1985 928 S3, 5-speed
1987 Carrera, current project
2012 Jaguar XF 5.0, Wife's d.d.
2009 Boxster,sold, 2000 Boxster, sold, 1995 993, sold, 2004 Maserati, sold, 2000 996, sold, 1971 914, my college car, 1966 911, sold way too cheep, Lots of VW's...
Old 08-29-2017, 11:25 AM
daltvater's Avatar
Thanks everyone, I spoke with Link who makes the ECU for my car. They said a dyne and remap is in order.
Gas here in New Zealand is 98 octane but that still isn't high enough!
Old 08-29-2017, 11:40 AM
