Attaching Rear Third Brake Light
A while ago I updated my 85 911 with a glass mount style, rear third brake light. I received the unit but without a way to attach to the glass. I looked at the stock rear glass of a 911 that had the light from the factory and it appeared to be painted where the light was mounted. This gave it a very clean look.
I ended up using a black double-sided foam tape to mount. The problem with this is that the tape shows a bit of non adhesion. Therefore it doesn't look 100%.
Are there any tricks or is there mounting harware I'm not aware of?
TIA.
Rick
Old 02-03-2003, 02:40 PM
Bump
Warren & Ron, may you rest in Peace.
Old 02-03-2003, 07:49 PM
