Wrightwood gaskets
Hi,
Got the kit today but have no idea what the big washers are for.
1974 911 coupe 4 speed |
Oil drain. I order those in quantity. Way better than those thin green ones, silicone or not. A gasket needs some compressibility.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 05-28-2018 at 02:03 PM.. |
kava..best gasket set you can get in these days;-) i have been using them for many many years..
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Worth every penny. John
83 911 Production Cab #10
Nice touch, they figure that if you are changing the valve cover gaskets chances are you are doing an oil change as well.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Hi guys,
I was wondering where I could buy one of those gasket kit ??. Thanks |
Deftom.... from Pelican parts;-) of course
Ivan
Hi Ivan
,I was talking about de engine gasket sets, not only cover... And I don't see it on Pelican parts |
look, here is the part number for the set from our host
930-100-907-04-W-INT or here https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_ENGCYL_pg2.htm#item3
great thanks
Formerly known as Syzygy
Pelican shows three different Wrightwood gasket sets - am curious which are the ones to get.
One is obviously the ones with the silicone bead on the exhaust side, but which of the other two sets is the recommended thick grey ones?
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 05-29-2018 at 04:34 PM.. |
looking forward to installing these as what I installed before (i think they are oem or oem like) are leaking, no other leaks on the car after winter project.
I also might have tightened them too much, so lesson learned.
Search the maker's name.
