engine compartment seal installation
would anyone know if i have to use adhesive on the engine seal #12 in this diagram. Dry fitting the seal does not appear to be correct.
thanks
1975 911S Targa Silver Anniversary Edition |
No. You don't have to use adhesive. The newer type seals (T shaped part that seats into the channel with a V notch in it) are very easy to install. I had an old style seal (without the V notch) I fought with to try to slide into the channel & realized I'd never be successful. Bought the new type seal from out host & had it installed in less than 20 minutes. It's still in there. Same thing for the seal strip behind the engine.
Marv Evans '69 911E |
seal
thanks for the information.
One tip for instillation. If you look at the ends of the metal channel that the seal goes into, you will see they have been bent closed to hold the old seal. Use a tool to unbend so the new seal goes in easier. Rob
as 30we...said check the lips and also use liquid soap to install...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
