throttle plate opening under WOT question
I have the 80 911 throttle boot off and was just checking everything before trying to restart the car after 16 years....curious question
Does the throttle plate only open about an 1" about 45 degrees when floored? I figured the butterfly would open alot more, like almost from flat closed _ to l position....make sense?? Like a butterfly on a carb??
Old 09-12-2017, 08:53 AM
T77911S's Avatar
the butter fly should be vertical at WOT.
16 yrs is a long time. if you are still in there make sure the plunger in the fuel dist is not stuck.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-12-2017, 09:08 AM
okay so I have a problem with the throttle body...when floored the butterfly only opens at 45 degrees, not 90....
next step linkage?
Old 09-12-2017, 09:10 AM
OffCamber00's Avatar
next step linkage?
yes, linkage.
Mat P
1988 911 Carrera
Old 09-12-2017, 09:55 AM
Registered Minimalist
75 911s's Avatar
A good while you're in there is a pedal cluster rebuild, throttle bushings in tunnel, bell crank throttle bushings (bronze) and new springs on the linkage.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-12-2017, 10:19 AM
next step linkage?
Pop off the linkage at the throttle body and make sure it opens fully, then work your way down the line to see what is out of adjustment.
Rutager West
Old 09-12-2017, 03:34 PM
Fixed
Someone removed what looks like the cruise control bracket off the throttle plate linkage and put the screws back in.... and it was stopping the linkage from moving to fully open.
Old 09-12-2017, 05:34 PM
That will do it, glad you found the problem. How does it drive now?
Rutager West
Old 09-13-2017, 01:29 AM
