Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
What tape to use to mask wheels prior painting?
Have stripped old paint off my Fuchs, now need to mask off the rims prior re-painting. Is there a special pliable tape to use in order to mask the 360 deg curve of the wheels?
'79 911SC Targa
Old 09-04-2017, 05:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Banned for Life
RSBob's Avatar
3M makes a 1/16" blue tape which is great for curves. Auto body shops and Amazon carry it.
Rick S, '71 914 3.0, '82 911SC
Old 09-04-2017, 05:22 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
+1 on the 3M tape. It's the vinyl stuff you want. I use 1/4" to make the compund curves and then switch to the cheaper, wider blue paper tape.
Old 09-04-2017, 05:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Go for the real 3M I used a cheaper version and it lifted in some spots leaving a blurred transition instead of nice and sharp.
Old 09-04-2017, 06:29 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
You want to use some sort of narrow vinyl tape for the edges, like Fine Line. Then mask the remaining larger areas just over the edge of the vinyl tape with some sort of regular masking tape. Cheap tape acts, well, cheap. It doesn't stick as well or, ironically, release as well, either. This is one area where you get what you pay for.
The vinyl tape will give you a nice sharp edge where the blue painter's tape won't. Some have used electrical tape for that sharp edge, but it's a little to wide to be flexible enough to steer around the multiple compound curve corners.
Kevin
Old 09-04-2017, 07:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Thanks gents - ordered
'79 911SC Targa
Old 09-04-2017, 07:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Fixer's Avatar
3m automotive tape is yellow now. It's what you need to tape off the rim as it really sticks. Prep with xylol prior for best adhesion.
It's carried at your local Sherwin Williams paint store or automotive paint supply house.
Good luck.
Matt Mariani, Philly Pa
RSC
1978 Super Carrera Coupe 'Foxy Brown' Mocha/Cork
1969 911E targa Crystal Blue / Black
1968 SWB 912 "Stinger 912R 1677 lbs
Old 09-04-2017, 07:25 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
JMT JMT is online now
I use pin striping tape from the local FLAPS. It's flexible and gives a nice sharp line.
Old 09-04-2017, 07:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
If you just want to paint the centers black, no taping necessary. Just have some lacquer or enamal thinner handy and try to keep most of the overspray off the outer rim. Wet a shop rag with thinner and carefully wipe the outer rim clean asap.
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 09-04-2017, 07:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
I used electrical tape on the areas where I needed the tape to stretch or bend a little around the tricky corners then used blue masking for the rest.
Old 09-05-2017, 04:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Flojo's Avatar
there's a special made 3M countour tape, that a) does curved areas nicely and b) doesn't disolve from paint
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 09-05-2017, 04:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
