Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Hey, nice marmot.
tirwin's Avatar
Singer wheel lug studs & nuts?
I took this picture of a Singer wheel a while back. I'd like to replicate this look. Any guesses at how long these studs are?
Also anyone know where I could buy open lug nuts in a yellow chromate finish?
Thanks in advance...
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 09-04-2017, 05:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Under the radar
Trackrash's Avatar
Location: Sebastopol, The Republic of California. Land of wine and redwoods.
Those are the same as VW Beetle nuts, 14mm threads. Porsche-Style Nut -14mm-1.5, Set of 5: VW Parts | JBugs.com
Gordon
_____________________________________
'71 911 Coupe 3,0L outlawed
Old 09-04-2017, 06:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Magnus Walker does something similar with the stud length, I looked it up at one stage and I think he uses 72mm studs. A bit of googling around that should probably find the answer ...
Old 09-04-2017, 06:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Canadian newbie
Oyagi's Avatar
Didn't know that was a thing. I have extra long studs on my 930 and opened ended nuts like the ones pictured and it drives me nuts (pun intended).
Old 09-04-2017, 07:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Hey, nice marmot.
tirwin's Avatar
Thanks, Gordon and Simon. That helps.
I assume a regular deep 19mm socket is long enough. I wonder if a shorter stud is used in front?
Oyagi, if you don't mind me asking, what drives you nuts about it? I always thought that was 'normal' for the RSR wheels.
Old 09-04-2017, 08:02 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Formerly known as Syzygy
Canada Kev's Avatar
I'm not sure if the factory studs are different lengths front vs. rear on an '87 Carrera, but just today I had my wheels off and tried an open nut to see how much of the stud protruded past. Both front and rear were identical at probably about 2 mm past the end of the nut.
Kevin
Old 09-04-2017, 08:14 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Hey, nice marmot.
tirwin's Avatar
Thanks, Kevin.
I am running 7.5 & 9/17 Linea Corse Fuchs. My rear tire is a 255/40 and the Singer is running a 265/40. The 265 was pretty stretched, so I'm guessing it was a 10x17 wheel on the rear. No idea what offsets the Singer uses.
Right now on my car the closed end lug nuts protrude past the opening about 2-3mm in the front and 8-9mm in the rear. If I'm thinking about this right the difference is the wheel offset.
I guess I need to find out what the available stud lengths are and take some measurements.
Old 09-04-2017, 08:48 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Try JimmyT on ESR
FS: 67S Lug nuts, Closed-end, 999.182.001.02
Old 09-04-2017, 09:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Flojo's Avatar
is it really for the long stud-look or rather for the open-lug-look?
Regards, Flo
79 SC - Frankfurt, Germany
visit me on www.facebook.com/911garage
Old 09-04-2017, 11:50 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Canadian newbie
Oyagi's Avatar
When I bought my car it came with extended rear studs and the previous owner was running 2x25mm spacers in the rear so that he could use narrow bodied Ruf wheels. I swapped back in wider wheels that eliminated one of the rear spacers but it resulted in needing open ended lug nuts and it just looks kinda unfinished.
Old 09-05-2017, 04:00 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
... Any guesses at how long these studs are?...]
Too Long...
Who Will Live... Will See
83 911 Production Cab #10, Slightly Modified: Slanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger
Old 09-05-2017, 04:19 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
911SC Tinkerer
Thanks, Kevin.
When Chris Harris interviewed Rob Dickenson about the cars, Rob said they were using 9s in front and 11s in the rear. Maybe that changed.
-Steve
-'83 911SC Coupe
SSIs, Dansk 2in - 2center-out, Street Fire Ignition, Copper plugs, Instagram: @ Zinnmetallic_sc
Old 09-05-2017, 05:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Hey, nice marmot.
tirwin's Avatar
open lug.
I have some steel open lugs nuts that I tried but it didn't look right for some reason. Seemed like the lugs looked too short.
Old 09-05-2017, 05:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Hey, nice marmot.
tirwin's Avatar
Originally Posted by JJ 911SC View Post
Too Long...
I kinda like pokies.
Old 09-05-2017, 05:31 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Hey, nice marmot.
tirwin's Avatar
-Steve
That makes sense.
Maybe I took a picture of the front tire but I could've sworn it was the rear.
Old 09-05-2017, 05:35 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Hey, nice marmot.
tirwin's Avatar
Originally Posted by 1968DT View Post
Thanks for the pointer.
Old 09-05-2017, 05:50 AM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Bill Verburg's Avatar
If going the exposed stud route I'd want bull nose studs
Bill Verburg
Old 09-05-2017, 06:00 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
JJ 911SC's Avatar
Found this thread about bull nose studs, thanks Bill.
Would any one know where to obtain lug nuts like those used by "Singer"?
https://swayaway.com/product-category/wheelstuds/
Old 09-05-2017, 06:33 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Hey, nice marmot.
tirwin's Avatar
Thanks, Bill and JJ!
I'm going to have the rear wheels off soon to do some work so I'll take some measurements. Those links were very helpful!
Old 09-05-2017, 12:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Under the radar
Trackrash's Avatar
Not sure what look you are going for. These are real 8" Fuchs with OE studs.
Long studs on my Bug. Same lugs.
Gordon
Old 09-05-2017, 04:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
