-   -   What to do regarding rusty flywheel? 3.0 SC / 914-6 Swap (http://forums.pelicanparts.com/porsche-911-technical-forum/969113-what-do-regarding-rusty-flywheel-3-0-sc-914-6-swap.html)
RichPugh 09-05-2017 12:17 PM
I'm starting an SC swap into my 914... I'm gonna grab the Kennedy adapter ring for 9-bolt flywheels and a 225mm clutch kit to keep my 901 trans but I didnt think I should simply ignore this rusted flywheel. It all seems to be superficial surface rust so... let it soak in a rust dissolver solution or de-ruster? Brake-clean and some steel wool? Scotch-brite and CLR? What do you think...
Edit: I do plan to take it off to inspect and most likely replace the RMS.
https://c1.staticflickr.com/5/4406/3...a1f8bb08_b.jpg
Flat6pac 09-05-2017 12:20 PM
Install the clutch, it'll clean where it runs
pampadori 09-05-2017 12:25 PM
can you drop it off at a machine shop and have them media blast it and then chuck it on the lathe to ensure a flat surface?
Without knowing more than I do, thats what I'd do if it were me.
RichPugh 09-05-2017 12:27 PM
That's what I initially thought but figured I'd ask. Thanks.
RichPugh 09-05-2017 12:29 PM
Yeah I probably can. I guess better safe than sorry but I don't think anything is questionable with it's true-ness.
GaryR 09-05-2017 12:32 PM
If it's coming off I would sandblast it if it was mine..
sixbanger 09-05-2017 02:15 PM
I think if you put the 3L in the 914 you will need to change the flywheel anyway.
RichPugh 09-06-2017 10:48 AM
Nah, the stock 225mm 9-bolt flywheel stays on the 3.0 engine and Kennedy (or Patrick MS) offers an adapter ring "kit" to mate a 228mm clutch which works with the stock 901 trans clutch operation :thumbsup:
Steam Driver 09-06-2017 11:14 AM
I don't think sand/media blasting is a good idea as it would leave a much rougher surface than normal and maybe make it "grabby." I would Scotchbrite the devil out of it then reinstall and let normal usage do the rest.
gomezoneill 09-06-2017 12:18 PM
Have it resurfaced at a machine shop.
85911 09-06-2017 04:04 PM
+1. In the old days, when we changed clutches we had our flywheels turned to remove grooving from worn out driven (clutch) plates and to make sure they were flat and true from warping due to heat.
Is the ring gear pressed on? I easily installed a new one on a different car by heating the ring and putting the flywheel in the freezer. It fell in place.
Jeff NJ 09-06-2017 04:40 PM
Blanchard grinding is the best option, IMO.
RichPugh 09-06-2017 04:59 PM
After speaking to several other people, I think the move it to either lightly scotchbrite it (if there is no reason to believe the flywheel is pitted or warped) OR just have it resurfaced at a local machine shop. I think the 2nd option is probably not cost prohibitive so I'll probably just do that. Thanks everyone :)
One more pic for project posterity, lol
https://c1.staticflickr.com/3/2812/3...c3829ff6_b.jpg
gomezoneill 09-07-2017 05:27 AM
Great photo panning with the car. Beautiful car love the color and the red decal.
RichPugh 09-07-2017 10:24 AM
Thank you! The PORSCHE letters are Orange :)
gomezoneill 09-07-2017 11:52 AM
You're to big to be driving that car you should sell it to me!
RichPugh 07-08-2019 08:20 AM
LOL... No.
Also, I took the flywheel to a local machine shop and couldn't be happier.
https://live.staticflickr.com/65535/...930e6cab_c.jpg
https://live.staticflickr.com/65535/...ce5ca5fd_c.jpg
ChieftanMews 07-08-2019 09:50 AM
Wow that cleaned up nicely!
