Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
froggert's Avatar
Originally Posted by mickey356 View Post
Froggert, I got my pedal today. What specifically did you want measured? Was pre install or post?
I'm looking for the distance between the pivot point on the ground and the furthest mounting hole for the threaded rod. I'm trying to quicken the accelerator by increasing mechanical advantage and want to compare the distance on the D-Zug versus Rennline and stock pedals. Thanks.
Old 09-11-2017, 08:15 AM
  Pelican Parts Technical Article Directory    Reply With Quote #21 (permalink)
Racer
winders's Avatar
If you increase the mechanical advantage of the pedal, you INCREASE the travel.
Scott Winders
PRC GTL #3
Old 09-11-2017, 08:28 AM
  Pelican Parts Technical Article Directory    Reply With Quote #22 (permalink)
The rod is all thread and there are multiple holes on the back of the pedal. Also it has two sets of mounting holes at the base which also gives more adjustability. I'd say you could set this up anyway you desire, even use a longer piece of all thread if the one it comes with isn't enough. I will post a couple pics I took later but I'll tell you the difference was immediate. MUCH BETTER response, no lag.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 09-11-2017, 08:30 AM
  Pelican Parts Technical Article Directory    Reply With Quote #23 (permalink)
froggert's Avatar
Would I need to use the highest or lowest mounting hole to decrease the pedal travel? Maybe I have this backwards..
Old 09-11-2017, 10:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #24 (permalink)
Lowest will make the pedal prouder along with the forward base mount to push the base further back.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 09-11-2017, 05:43 PM
  Pelican Parts Technical Article Directory    Reply With Quote #25 (permalink)
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 09-11-2017, 05:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #26 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
I'm not the brightest bulb on the tree but wouldn't it be relative to the rods and pivot points, etc...? I sucked at physics in school so I can't make sense of it but my old stock pedal with an aluminum add on had a bit of play in it....you could push the pedal an inch in before the throttle would rev. This pedal removed all of that; the second my foot touches the pedal and starts to depress it responds. Maybe I just had a crappy pedal before.
1983 SC - sold
2002 996 C4S - sold
1968 912
Old 09-11-2017, 05:49 PM
  Pelican Parts Technical Article Directory    Reply With Quote #27 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
Somehow your new installation removed the slack in the linkage, so its all good.
I had the same problem and spend hours of adjustment fiddling from the front to the back before I eliminate that lag.
Just enjoy it
Who Will Live... Will See
83 911 Production Cab #10, Slightly Modified: Slanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger
Old 09-11-2017, 06:41 PM
  Pelican Parts Technical Article Directory    Reply With Quote #28 (permalink)
froggert's Avatar
Thanks for the pictures! I'm running a throttle cable instead of the stock rod in my car and have adjusted the play already.
Old 09-13-2017, 10:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #29 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
