jpgroth's Avatar
'79 SC and Porsche Newbies
Hello all!
My dad just picked up this '79 SC; fulfilling a dream of many many years. We drove it home to Milwaukee this past weekend from Indy. Both of us are new to Porsche, and the old man is new to wrenches and sockets in combination with autos. He's spent lots of time listening to me talk shop about my viggen, and has stared in awe numerous times with the car ripped apart in his garage.
Anywho, I figured this was a good spot to ask questions, show progress, and learn.
A couple things we want to address right off the bat..
1. The car is from Georgia; the sun has taken its toll on the window trim. It's cracked quite a bit. Does this require window removal?
2. We had a PPI done from a Porsche guy. He was talking about a light relay (possibly high beams?) that was failing, or was known to fail on the cars. It sounded like an easy fix, but I wasn't quite following which set of lights he was talking about.
3. The PO had switched steering wheels. The horn doesn't work, and the turn signals don't automatically stop. Seems like an easy wiring step was missed here? It currently has the 4 spoke; the old man wants to put in something a bit sportier. I've seen them on the classifieds..is there an universal hub for those? Or should it be specific to the SC?
4. One headlight is cracked. Just the glass lens. The mechanic also told us that the car had H4 lights. What's a good source for smaller parts like this?
5. The minute we got home.."We need a mean ass exhaust on here." I've done a little research on the Bismoto unit, but it seems a bit harsh and I'm not a fan of the way it looks. Is the SSI/Dansk the way to go? Best place to source SSIs?
I've been doing research here and there; I'm sure most of these questions are basic. I'll keep snooping around. Thanks in advance!
Old 09-05-2017, 06:02 PM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
0. Do you have an Owner's Manual? Great source of information. Wayne has a book "101 Projects for your 911 Porsche" get it.
1. Windows out to change the rubber window seals.
2. An owner's manual or workshop manual will detail the relays.
3. I think all the aircooled 911s have the same steering hub. Lot's of options for steering wheels new and used. Check out the "Used Parts for Sale" forum.
4. Click on the "Parts Catalog" at the top of this page. Pelican probably has them.
5. IF you don't need to get your car smog checked a "back dated" exhaust like a SSI is the way to go for your car.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-05-2017, 07:29 PM
Bill Douglas's Avatar
A great looking car - well done.
see www.lyallbaybeach.co.nz
Old 09-05-2017, 07:40 PM
billybek's Avatar
Very nice!
Welcome to the forum.
Bill K.
83 911 SC Guards Red
And a bunch of parts I haven't installed yet.
Old 09-06-2017, 05:46 AM
Bill Verburg's Avatar
A common oe failure point is the steering column mounted H/L headlight switch
many add a relay for at least high beams to lighten the current load thru the switch.
Bill Verburg
Old 09-06-2017, 05:55 AM
TheSt|G's Avatar
Have to see it to make a call.
The headlight switch for the highbeams is hardwired from the stalk on the steering column to the lights themselves. Common upgrade is to add a relay to take the load off the column switch. Switch often breaks otherwise. There are a couple other fuse/relay projects like that.
Yes, most of the aircooled 911s share a hub. Most people use the Momo style one. Horn is a single wire and a grounding ring. Turn signal is a mechanical reset.
Not going to be cheap to get proper original Bosch. Lots of fakes out there.
Older SSIs are supposedly better than the current Dansk versions.
M&K makes some of the best exhausts for this platform from a quality perspective.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
86 ssinit's Avatar
Nice looking car good luck with it. Enjoy it!!! Take your time with it. You just got it so go out there and drive it. Don't worry about the window seals yet you have a garage. High beam relay probably inst there. It wasn't stock from porsche. It's an add on lots of threads on it here and it's a cheep fix that should be done. As said go to the parts for sale for steering wheel get one with a memo hub. I'll get back to you with the number. Once you have the hub all momo wheels will fit. I now have 5 it becomes addicting. For the exhaust I have a set of B&B headers on my sons 83 sc. it's not a daily driver and there loud. Also adds some horsepower. I like them so I added a B&B sport muffler to my 86. Again it's loud but being in NewYork loud pipes save lives��. Again good luck with it and drive it.
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 09-06-2017, 06:09 AM
Cars and Cappuccino
tdw28210's Avatar
Welcome.
Old 09-06-2017, 06:48 AM
jpgroth's Avatar
We got around to some things this past weekend. The first thing we tackled was the Wevo PSJ. It helped gear selection feel but there is still a solid amount of play in the shifter. It sounds like the Wevo short shifter is worth its price tag..? I've also been reading that Swepco trans fluid seems to be made of unicorn dust. Is 1 gallon enough for a flush?
Secondly, we pulled the gauges and put in new 12v 2w bulbs...no lighting change. Looks like we'll be looking into a LED option.
And lastly, we started on a prototipo. It appears the hub I got from a forum member didn't come with the spacer we need. There's about a 1-2" gap between the hub and the steering column shroud. Where can I pick up just the spacer? And, after pulling the original wheel, we noticed that the blinker reset ring is no where to be found, damn! Any options on this? Sounds like the part is NLA
Old 10-29-2017, 06:19 PM
911 Mania
Nice car, for LED’s try Carmagic, he’s a forum regular with user name rothaus. I’ve ordered from him before with great results.
Carmagic, LED Lights for Classic Porsches
Good luck!
Hemmingway said it best, “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
Old 10-30-2017, 07:06 PM
Flojo's Avatar
the Momo hub does not sit 100% flush, no spacer.
get the blinker reset from eBay as used.. beware: you need the one with the long finger (the short ist for 924/944/968 and will not work)
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 10-31-2017, 01:14 AM
jpgroth's Avatar
We're finally getting around to some work. We've had a prototipo installed for a bit and just made a deal for a horn ring and turn signal cancel, which brings me to my questions. I'm assuming the ring attaches to the backside of the hub via three screws, but the holes aren't quite lining up between the ring and hub. Is this common or do I have the wrong cancel ring? I'm tentatively thinking I'll line up the two holes that match and then drill out a third hole on the hub with a drill press.
The cancel ring gets mounted here, horn wire fed through bigger hole and connected to metal spacer? Or should it connect to the back of the actual horn pad? I realize I can check this with guess and check on the car, but I'm here writing the post..
Old 04-14-2018, 06:50 PM
jpgroth's Avatar
I pulled most of the exhaust this weekend because we got this in mail this past week
SSIs are getting ordered tonight. Our oil lines are seeping pretty good so I'm working on pulling those as well to have them shipped to Len for some refurbishment. Damn lines are a BEAR
Old 04-14-2018, 07:13 PM
82 911 SC - Ancora Imparo
Which exhaust is that? Considering changing mine too- definitely give us a review, please!
Old 04-14-2018, 07:35 PM
jpgroth's Avatar
We went with a Monty Muffler, #M21. I do freelance photography/video work; an in depth video will definitely be uploaded once the system is installed. I'm building some nerves about removing the original heat exchangers, I cut most of the original exhaust hardware with a saw to remove the muffler and cat
Old 04-14-2018, 08:07 PM
Formerly known as Syzygy
Canada Kev's Avatar
Welcome to the forum!
You seem to have your list of stuff to do in order.
It's difficult to tell for sure from your photos, but it looks like you don't have the lip spoiler on the front valence. This really is something you should have in conjunction with the rear tail to reduce aerodynamic instability at speed.
The rule is:
Front + rear = good
Front + no rear = questionable, some say yes, some say no, never offered by the factory in this configuration
No front + rear = no go, nada, don't do it
Kevin
Old 04-14-2018, 08:34 PM
