Delete A/C, finally got rid of that compressor bracket
I finally removed that a/c bracket that use to support the compressor. I finished the a/c delete last year and that bracket was bugging me. I was avoiding that bracket as some of the exhaust system had to be pulled. As usual once I got going it wasn’t that bad. I also fabbed and installed a block off plate for the hole.
Before http://forums.pelicanparts.com/uploa...1504745147.JPG After http://forums.pelicanparts.com/uploa...1504745203.JPG Bracket (2.4 lbs), M&K muffler and hot air duct http://forums.pelicanparts.com/uploa...1504745240.JPG Inside M&K pre-muffler (tip of O2 sensor in back) http://forums.pelicanparts.com/uploa...1504745371.JPG Inside left heat exchanger http://forums.pelicanparts.com/uploa...1504745442.JPG Hole left from bracket http://forums.pelicanparts.com/uploa...1504745488.JPG Close out plate .025" aluminum http://forums.pelicanparts.com/uploa...1504745631.JPG Installed close out http://forums.pelicanparts.com/uploa...1504745725.JPG Rear of car with no valence, I don't even notice. Maybe leave off.... http://forums.pelicanparts.com/uploa...1504745834.JPG |
Great post.... surprised the bracket is 2.4 pounds, it's a lot bigger than I thought.
What rear bumper is that?
I removed my AC over 3 yrs ago and my AC bracket still remains in place. Your thread has me motivated.
Sent from my iPhone using Tapatalk |
| All times are GMT -8. The time now is 03:05 AM. |
